Solved! Go to Solution.
MyNewAddin_addin.somecombobox
somecombobox.value
Kevin,
I see you still don't have any answers for this. Can you provide more information with your question? For example: the whole piece of code you are using, the error you are receiving...
I am not familiar with any of the new features in 10.1, but in 10 you get values from inputs (including, I presume, comboboxes) via arcpy.GetValueAsText(). Or are you using something like Tk?
import arcpy import pythonaddins class BufferTool(object): """Implementation for MultiBuffer_addin.tool (Tool)""" def __init__(self): self.enabled = True self.cursor = 3 def onMouseDownMap(self, x, y, button, shift): buffers= {"buffer1": [70, 1200], \ "buffer2": [110, 1700],\ "buffer3": [150, 1850]} sr = arcpy.SpatialReference(arcpy.Describe("parcels").spatialReference.factoryCode) pt = arcpy.PointGeometry(arcpy.Point(x,y), sr) arcpy.env.overwriteOutput = True arcpy.env.addOutputsToMap = True ptfeat = arcpy.management.CopyFeatures(pt, r"in_memory\pt") buff = "{0}".format(BufferType.value) print buff print buffers[buff] theBuffers = buffers[buff] #arcpy.MultipleRingBuffer_analysis(ptfeat, r'in_memory\blastzone', [200, 400]) # works arcpy.MultipleRingBuffer_analysis(ptfeat, r'in_memory\blastzone', theBuffers) arcpy.RefreshActiveView() class BufferType(object): """Implementation for MultiBuffer_addin.distance (ComboBox)""" def __init__(self): self.hintText = 'buffer type' self.items = ["buffer1", "buffer2", "buffer3"] self.editable = False self.enabled = True self.dropdownWidth = 'WWWWWWWWWW' self.width = 'WWWWWWWWWW' def onSelChange(self, selection): print self.value
somecombobox.value
