Loop through Columns and Rows
5943
8
04-19-2012 10:45 AM
RichardThurau
I am trying to use an update cursor to loop through all fields and all rows and replace 0 with 9999. I've looked up a column command that appears to work for some people, but is not going well for me.
Here's the code:
import arcpy, os from arcpy.sa import * from arcpy import env arcpy.CheckOutExtension("Spatial") arcpy.env.overwriteOutput = True  areaTab1 = r"X:\DATA\ROW_SP_areaTab"  rows = arcpy.UpdateCursor(areaTab1) for row in rows:     for col in rows:         if row.getValue(row) == 0:             row.setValue(9999)             row.updateRow(row)
Error:
  File "C:\_Rich\Project_Temp\col_loop_test.py", line 13, in <module>
  File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\arcobjects\arcobjects.py", line 945, in getValue
    return convertArcObjectToPythonObject(self._arc_object.GetValue(*gp_fixargs(args)))
RuntimeError: ERROR 999999: Error executing function.
This would be awesome and incredibly useful to be able to run instead of having to search each individual field.
Any help would be greatly appreciated!!
Rich
MathewCoyle
Honored Contributor
Oh thats a typo
rows = arcpy.UpdateCursor(areaTab1) cols = arcpy.ListFields(areaTab1) for row in rows:     for col in cols:         if row.getValue(col.name) == 0:             row.setValue(col.name, 9999)             rows.updateRow(row)
BruceNielsen
I think you want:
if row.getValue(col) == 0:
RichardThurau
Thanks Bruce,
No dice. Same error. I also tried row.col and col.row, which I'm sure to the programmers out there, obviously would not work.
Here's some info about how to do it on StackOverflow:
http://stackoverflow.com/questions/2457193/looping-through-columns-in-a-csv-files-in-python
rt
DarrenWiens2
I'm not sure what the performance implications to this would be, but you might just abandon the UpdateCursor idea and run Calculate Field for each field. This is untested, but I think it should work.
import arcpy
inFeatures = r"X:\DATA\ROW_SP_areaTab
fieldList = arcpy.ListFields(inFeatures)
for field in fieldList:
    codeblock = "def func(field):\n    if field == 0:\n        return 9999"
    expression = "func(!" + field.name +"!)"
    arcpy.CalculateField_management(inFeatures, field, expression,"PYTHON",codeblock)
Alternatively, for your code you're looping through the rows twice, not the columns at all.
import arcpy, os
for row in rows:
    for col in cols:
        row.updateRow(row)
edit: changed some "col" to "col.name"
MathewCoyle
Honored Contributor
import arcpy, os
for row in rows:
    for col in cols:
        row.updateRow(row)
You'll want to indent under the field list loop as well.
for row in rows:
    for col in cols:
            row.updateRow(row
RichardThurau
Mathew and Darren, Thanks for your replies. This is making sense to me.
I push this code:
for row in rows:
    for col in cols:
            row.updateRow(row)
And now get this error:
  File "C:\_Rich\Project_Temp\col_loop_test.py", line 35, in <module>
    row.updateRow(row)
  File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\arcobjects\_base.py", line 25, in __getattr__
    x = getattr(self._arc_object, attr)
RuntimeError: Row: Field updateRow does not exist
The key being this last line where Python is looking for a field called "updateRow", which of course is not a field name. Seems like the syntax is good up to the last line, but why is it not recognizing the update command?
RichardThurau
P.S. Darren, I don't want to use calculate field because the real purpose of this code will be to replace Null values with zeros and I know, a couple service packs ago at least, field calculator has a hard time with Null values from Python.
rt
MathewCoyle
Honored Contributor
Oh thats a typo
RichardThurau
Frikin Beautiful!
Sorry for overlooking the rows., I tried not to miss any of that silly stuff but guess I failed.
Thanks to you both for your time and attention.
Rich
