ArcEngine 9.3 .Net Framework
916
04-18-2012 06:57 AM
IdrissEL_Achabi
Hi !
I recover a point in pGeometry (type : Igeometry) , and I would like to draw it in the screen, but I have some troubles with the following code :
            Dim pGraphicsContainer As IGraphicsContainer
            pGraphicsContainer = Form1.AxMapControl1.Map.BasicGraphicsLayer
            Dim ppoint As IPoint
            ppoint = New Point
            ppoint = pGeometry  !!!
            pGraphicsContainer.AddElement(pElement, 0)
            Form1.AxMapControl1.Refresh()
The cast is impossible between ppoint and pgeometry !!!
GeorgeFaraj
Hi !
            ppoint = New Point
Not exactly sure what you are trying to achieve (surely there is more code than this?) but if you want to construct a Point then:
        // in C#
        IPoint point = new PointClass();
        point.PutCoords( YourX, YourY );
this will do it.
AlexanderGray
Honored Contributor
All points are geometries, not all geometries are points.
It is possible that the igeometry passed in is of a different type like line, polygon etc.
if you write something like this, a failed cast will return null.
ppoint = trycast( pGeometry, IPoint)
If ppoint isnot nothing then
  'do something
else
  'geometry is not point
end if
You may also consider using IGeometry.GeometryType
