BaseCustomLayer Draw() use of IProjectedCoordinateSystem5
1242
04-11-2012 11:11 AM
ScottMcNeil
Using Arc 9.3.1 & VS2008.
Having trouble with converting spatial reference to PCS on a new development system only.  This worked fine on my previous development system (XP), and works fine on a production system (Win7).  But on the new system the conversion to PCS below always returns a null object reference.
    public override void Draw(ESRI.ArcGIS.esriSystem.esriDrawPhase drawPhase, IDisplay Display, ESRI.ArcGIS.esriSystem.ITrackCancel trackCancel)
      if (!m_bValid || !m_visible)
        return;
      if (drawPhase != ESRI.ArcGIS.esriSystem.esriDrawPhase.esriDPGeography)
        return;
       IProjectedCoordinateSystem5 pcs5 = Display.DisplayTransformation.SpatialReference as IProjectedCoordinateSystem5;
      // then the work is done which just puts markers on the map
Any ideas on why this is broken on my new development system?
Thank you if you can help!
ScottMcNeil
Additional Note:  In the debugger, the Display.DisplayTransformation.SpatialReference member does not seem have the correct value.  The debugger shows the reference as that of "System.__ComObject".  On the working system the debugger correctly shows the object is an ESRI.ArcGIS.Geometry.ProjectedCoordinateSystemClass.
