MapView Resolution Units Conversion
2457
04-04-2012 09:39 AM
LukeCatania
My maps are in Geographic WGS84.  When I use the getResolution method on the mapview, what units is the resolution in?  Radians?  Degrees?
How do I convert them to meters?  I tried
AngularUnit.convertUnits(mapView.getResolution(), Unit.create(AngularUnit.Code.RADIAN), Unit.create(LinearUnit.Code.METER))));
but received an error:
com.esri.core.geometry.GeometryException: invalid_call
IvanBespalov
Luke,
I'm not sure, but
http://services.arcgisonline.com/ArcGIS/SDK/REST/export.html
dpi
Description: The device   resolution of the exported image (dots per inch). If the dpi is not specified, an image with a default DPI of 96 will be exported.
Example: dpi=200
We tried to discuss here about it.
