Changing a Map Document's Description via python - Need Help
808
04-04-2012 06:26 AM
MarkFox1
So this should be a straight forward and simple code, but it's not working for me:
import arcpy
mxd = arcpy.mapping.MapDocument("G:/Projects/Phase II Project Location.mxd")
mxd.description = "Phase II"
When I run this script outside of ArcMap, then open the map document and check the Map Document Properties the map document's description does not get changed.
Am I missing something? I assumed this would be possible, yes?
Thanks for any help!
--Mark
MathewCoyle
Honored Contributor
You'll need this somewhere.
mxd.save()
MarkFox1
I knew it was something simple.
Thanks!
Mark
