Catchment  Polygon Processing
5642
04-03-2012 07:37 AM
JinweiQiu
After finishing Catchment Grid Delineation, I have a Catchment polygon processing problem, see below message:
ERROR 000210: Cannot create output C:\TEMP\JinWei\Catchment.shp
Failed to execute (Dissolve).
End Time: Tue Apr 03 10:34:18 2012 (Elapsed Time: 0.00 seconds)
System.Runtime.InteropServices.COMException (0x80004005): Error HRESULT E_FAIL has been returned from a call to a COM component.
   at ESRI.ArcGIS.Geoprocessing.GeoProcessorClass.Execute(String Name, IVariantArray ipValues, ITrackCancel pTrackCancel)
   at ESRI.APWR.ArcHydroGPTools.AHCatchmentPolyProcessing.Execute(IArray paramvalues, ITrackCancel trackcancel, IGPEnvironmentManager envMgr, IGPMessages message)
Failed to execute (CatchmentPolyProcessing).
End Time: Tue Apr 03 10:34:18 2012 (Elapsed Time: 2.00 seconds)
I have tried to clean the temp file and folder, but could not find any in my C drive. Any suggestion will be appreciated!
MattTarkington
Make sure that your file is being saved into a personal geodatabase. I believe that'll fix it. There's a tool to clean the temp files under "ApUtilities"
MarkBoucher
Occasional Contributor III
