ArcPad into ArcMAP export
3872
03-30-2012 03:21 AM
PeterMichalak
Hello guys,
I have a little problem trying to export a file from ArcPad to shapefile.
I'm new to ArcPad, so will try to explain the process.
The way the surveyors gather the data is:
Office provide them with road network shp (polyline) and blank manholers and crossovers shapefile.
They add a road layer (shapfile format) to ArcPAd and then draw manholes and crossovers while on site using Quick Capture.
After that the features are saved in the shapfile and than coppied across to laptop. However last time I couldn't do it
because I got an error saying "Could not open specific file" and "Number of shapes does not match the number of table records" while opening the shapefile.
DBF file look allright
Any idead guys?
Thank you have a nice day!
Regards,.
Peter
Tags (3)
TimHopper
Peter,
That's sort of a strange error to be getting.  That error seems to say that the shx file may have been corrupted and is having trouble putting the dbf and shp together.  I'm guessing if you ran it through this ArcScript you may be able to open it.  Read the header and then build a new shx.
How are you transferring these files back and forth between the mobile device and your computer?  Do you copy and paste the files with windows explorer or do you have a sync folder setup?  Are you trying to open these files in ArcPad or ArcMap?
Do you use ArcGIS Desktop as well?
If you do, I might focus on perhaps modifying your workflow to begin using the geodatabase.  If you can use ArcMap to check the data in and out from a geodatabase it would be much more stable.
Any additional info you have would help to get this on the right track.
Thanks.
JuanLuera
Peter,
I am including a few items of information with regard to the post by Tim. I am including some helpful ArcPad Help links and Technical articles, which should assist in this process. If the error/issues continue to occur, please reach out to us at Support Service. Gracias!
Get Data for ArcPad
http://help.arcgis.com/en/arcpad/10.0/help/index.html#//00s100000068000000
HowTo: Check Out/In data from ArcMap to ArcPad for editing
http://support.esri.com/es/knowledgebase/techarticles/detail/32862
HowTo: Export .dbf and shapefiles files from ArcPad Studio
http://support.esri.com/en/knowledgebase/techarticles/detail/32848
Support Service
1-888-377-4575
http://support.esri.com/en/webform/support/customerId/10275/chat/false
RolfBroch
I have users reporting this error as well and some of the users said that this happened when they took the SD card out of the unit without quitting ArcPad first.
Rolf
JuanLuera
Rolf,
If you could please submit a webform, and we can have a incident created for you on this issue. You can add my name, and I will be happy to work with you on this issue. Gracias!
Support Service
1-888-377-4575
http://support.esri.com/en/webform/s...275/chat/false
