StreetMap Premium North America TomTom data set - how to get into arcpad
4158
06-19-2012 06:11 AM
DanielHofer
I can't seem to get the Tom Tom data to show up in Arcpad.
This arcpad is on a netbook and not a mobile device.
My end goal is to see if I can route a bunch of points through the city.
I enter the code for the data and it was good.
I Navigate arcpad to the cd drive Z:
Per the instructions ArcGIS 10
Steps:
Tap the Add Layer button on the main toolbar.
Check the check box of the StreetMap file (.navmap) that you want to add as a layer to your map.
Tap OK.
Certain layers look like they are not loadable.  See attached graphic.  Then the two layers that look loadable when I load them I get errors
Default settings file 'C:\Documents and Settings\DAHOFER\My Documents\StreetMap.rxp' is absent or corrupted
Error opening 'z:\ArcPad 10.0.3 Streetmap Premium TomTom NA\_navi_na.navmap' : Error 0
Default settings file 'C:\Documents and Settings\DAHOFER\My Documents\StreetMap.rxp' is absent or corrupted.
Error opening 'z:\ArcPad 10.0.3 Streetmap Premium TomTom NA\_navi_na_day_night.navmap' : Error 0
If fixing these errors is my only issue, how do I fix them.
On a side note, since I have your attention, here is what I'm trying to figure out.  I've got a surveyor with 100 traps throughout the city.  I was hoping Arcpad can route him to the most efficient route.  It will probably take 3 or 4 days to service all the traps.  Any ideas?
Dan
Tags (3)
DanielHofer
I did the 'ol uninstall and reinstall to a newer version and that did the trick.
