Python Error With UpdateCursor
1320
03-16-2012 04:28 PM
ShaunWeston
I keep getting this error message when I try run a script to update some fields:
RuntimeError: ERROR 999999: Error executing function.
Workspace or data source is read only.
Workspace or data source is read only. [The C:\Data\Current Projects\Goldpine\Scratch.gdb workspace is read only.]
This seems to only come up when I run it on larger datasets?
This is my code:
import arcpy
# Overwrite existing data
import arcpy
# "C:\\Data\\Current Projects\\Goldpine\\Scratch.gdb\\ParcelsWithAddressPropertiesSELECTION"
# arcpy.GetParameterAsText(0)
myFile = "C:\\Data\\Current Projects\\Goldpine\\Scratch.gdb\\ParcelsWithAddressProperties"
sortField = "PAR_ID"
appendField = "Full_Address"
multiField = "MultipleAddresses"
parcelID = "PAR_ID"
rows = arcpy.UpdateCursor(myFile,"","","",sortField + " A")
for row in rows:
   if (row.FREQUENCY == 1):
      appendValue = row.getValue(appendField)
      row.setValue(multiField, appendValue)
      rows.updateRow(row)
   if (row.FREQUENCY > 1):
      x = 0
      addressList = ""
      while (x < row.FREQUENCY):
        if  (x == 0):
          previousParcel = row.getValue(parcelID)
          addressList = appendValue
          row.setValue("MultipleAddresses", addressList)
          rows.updateRow(row)
          x += 1
        else:
          currentParcel = row.getValue(parcelID)
          if (currentParcel == previousParcel):
             if (len(addressList) > 200):
                addressList = addressList
             else:
                addressList = addressList + " || " + appendValue
             rows.updateRow(row)
             x += 1
ChrisSnyder
Honored Contributor
Are you sure the FGDB isn't compressed (aka in a read only state)?
How large is a "larger dataset"?
WilliamIde
I have also got the dredded 999999.  For me it was because I had the FC that I was running the python script against open in arcmap.  Some sort of lock problem.  Try closing Arcmap and running your script.  Maybe even wait a few seconds after it closes.  It seems that the lock is not updated as fast as we would like.
JeffReinhart1
Looks like Shaun and I are trying to do the same thing, which is to assign a unique id to a field (mine is "LNDOWNR_ID") for any addresses that are the same in another field (mine is "TEMP1"), with the id being generated from a counter that gets updated if the next address is different than the last.
My guess is this is a memory issue�?� on the first run my process gets through 8002 records then quits (I queried the field that is being updated on "LNDOWNR_ID" IS NOT NULL in ArcMap after running it). I have tried running the script with only ArcCatalog running, and it still only gets through 8002 records out of 71000. I am running on a Windows XP machine with 3.48gb RAM. If anyone can shed further light on this, that would be appreciated.
My guess is Shaun has found a work-around by now, but here is mine: I am running the script in batches with a where clause in the update cursor:
UpdateCursor(inputFC, '\"LNDOWNR_ID\" IS NULL;', "", "", "TEMP1 A"
and bumping up the count for each run. Its tedious, I may as well have done the calculation in Excel.
