When I open ArcScene document with relative paths programmatically from ArcMap, all those paths are broken. The location in source tab for broken layers is set to some different path like "C:\Windows\System32" or "C:\Windows".Below is the code sample I use to open document. Both ArcMap and ArcScene projects are located in "C:\test" and so are files added to ArcScene doc.Sub test_relpaths()
Dim pDoc As IDocument
Set pDoc = New sxDocument
Dim iApp As IApplication
Set iApp = pDoc.Parent
iApp.OpenDocument ("C:\test\test_relpaths.sxd")
End Sub
When I use similar code to open ArcMap doc from ArcScene, everything is fine, relative links are kept:Sub test_relpaths()
Set pDoc = New mxDocument
iApp.OpenDocument ("C:\test\test_relpaths.mxd")
End Sub
Can anyone please help me to fix this issue or tell if it's a bug.
