How to create a circle as layer in ArcEngine using java?
1160
03-16-2012 02:05 AM
ApoorvaGora
I have to create a circle through a feature class, so that it can be added to the table of contents as a layer after creation and i can turn it on and off as required and also perform some analysis operations.
I have already created a circle as graphic but i don't know how to add it as layer, i have added it to the map as a element.
I know how to connect to work-space and feature class, put some values in it or delete some but can't figure out the way to draw a polygon(Circle) and add it as a layer.
So plz help me out,
Thanks in advance
Apoorva Gora
ApoorvaGora
No body ???
NeilClemmons
Honored Contributor
Use IFeatureClass.CreateFeature to create the new feature.  Use IFeature.Shape to set the geometry and use IFeature.Store to save it.
