create feature class in an add-in
989
5
03-07-2012 01:29 PM
ChrisBradberry
Hey,
I think that I figured out the problem that I am having, but not the solution.  I have an add-in that creates a feature class if it does not exist.  Sometimes it works and sometimes it gives a com error. I finally came to the conclusion that when the default.gdb (or the outpath) has a path in the name (as in windows xp default location) the createfeatureclass_management call has a com error.  When you work on a windows 7 computer without a space in the default.gdb it works fine.  Of course the developer computer was windows 7 and always worked, but the users computers had failures.
My question is how do you submit the CreateFeatureClass_Management geoprocess when the outpath path has a space in it?  I know you can do it from ArcMap, but how does it work in the add-in?
Thanks, Chris
KenBuja
MVP Esteemed Contributor
This is how I create a new feature class using the Geoprocessor in my add-in
    Friend Function CreateFeatureClass(ByVal FCLocation As String, ByVal FCName As String, ByVal pSR As ESRI.ArcGIS.Geometry.ISpatialReference3, ByVal GeometryType As String) As ESRI.ArcGIS.Geodatabase.IFeatureClass
        Dim CreateFClass As New ESRI.ArcGIS.DataManagementTools.CreateFeatureclass
        Dim Result As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2
        Try
            Using releaser As New ESRI.ArcGIS.ADF.ComReleaser
                releaser.ManageLifetime(CreateFClass)
                CreateFClass.out_path = FCLocation
                CreateFClass.out_name = FCName
                CreateFClass.spatial_reference = pSR
                CreateFClass.geometry_type = GeometryType
                Result = RunTool(CreateFClass, Nothing, True)
                If Result Is Nothing Then Return Nothing
                Return ReturnObjectfromResult(Result, "Feature Class")
            End Using
        Catch ex As Exception
            System.Windows.Forms.MessageBox.Show(ex.ToString & vbNewLine & ex.StackTrace.ToString, "Create Feature Class")
            Return Nothing
        End Try
    End Function
    Friend Function ReturnObjectfromResult(ByVal result As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2, ByVal Type As String) As Object
        Dim GPVal As ESRI.ArcGIS.Geodatabase.IGPValue
        Dim InMemFC As String
        Dim GPUtil As ESRI.ArcGIS.Geoprocessing.IGPUtilities3 = New ESRI.ArcGIS.Geoprocessing.GPUtilities
        Try
            GPVal = result.GetOutput(0)
            InMemFC = GPVal.GetAsText()
            Select Case Type
                Case "Feature Class"
                    Return GPUtil.OpenFeatureClassFromString(InMemFC)
                Case "Table"
                    Return GPUtil.OpenTableFromString(InMemFC)
                Case "Feature Layer"
                    Return GPUtil.OpenFeatureLayerFromString(InMemFC)
            End Select
            System.Windows.Forms.MessageBox.Show(ex.ToString, "Return FeatureClass error")
            Return Nothing
        End Try
    End Function
    Friend Function RunTool(ByVal Process As ESRI.ArcGIS.Geoprocessor.IGPProcess, ByVal TC As ESRI.ArcGIS.esriSystem.ITrackCancel, Optional ByVal AddOutput As Boolean = False) As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult
        Try
            System.Windows.Forms.Cursor.Current = Windows.Forms.Cursors.WaitCursor
            Dim GP as New ESRI.ArcGIS.Geoprocessor.Geoprocessor
            GP.OverwriteOutput = True
            GP.AddOutputsToMap = AddOutput
            Result = CType(GP.Execute(Process, Nothing), ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult)
            If Result.Status <> ESRI.ArcGIS.esriSystem.esriJobStatus.esriJobSucceeded Then
                Return Nothing
            End If
            Return Result
            Return Nothing
        End Try
    End Function
ChrisBradberry
Ken,
Thanks, I will try that out and let you know.
Chris
ChrisBradberry
Ken,
The code works for a feature class path that does not have a space in it, but still throws a com error when the feature class path has a space in it.  There should be a way around this because the tool in ArcMap will work when the path has a space in it.
Any other ideas?
Chris
KenBuja
I just ran a test with the application that uses this code and I didn't receive an error when I created a new dataset in the directory C:\temp\New Folder\. This is on a Win 7 machine.
Where are you getting the error?
ChrisBradberry
Ken,
I am using a win 7 machine too, and get the error when I try to create the feature class. I have elevated this to tech support.  I imagine that I have used some bad coding practices.  Thanks for the help.
Chris
