Accessing Arcobjects from Excel
1024
03-06-2012 10:37 AM
VikramS
Hello ,
I am trying to access arcobjects from excel vba . But I am getting an error . Below is my script . i have added all the references relating to ESRI .
Dim pworkspacefactory As IWorkspaceFactory2
Set pworkspacefactory = New FileGDBWorkspaceFactory
Dim pworkspace As IWorkspace
Dim s As String
s = "H:\\SPSD\\SPSD1.gdb"
If pworkspacefactory.IsWorkspace(s) Then
Set pworkspace = pworkspacefactory.OpenFromFile(s, 0) getting error here (Run-time error '-2147220952 (80040228)')
MsgBox pworkspace.PathName
I have another question as well .. Can we pass parameters to Arcmap if we open it through a batch file
Please help me
NeilClemmons
Honored Contributor
Are you checking out a license?  If not, then your code won't run.  Also, if you're using ArcGIS 10 then you will also have to bind to a product before checking out the license.
VikramS
Hi Neil ,
Thanks for the reply . I had a quick question .. How to check out a license ?
NeilClemmons
Honored Contributor
Use IAoInitialize.
