Save a Join
1077
03-01-2012 01:39 PM
GeorgeFaraj
I seem to remember seeing some code to do this and now I can't even remember what to call it. If I have created a Join using a memoryRelationshipFactory then I am using it dynamically. What is it called if I want the Join fields to become part of the featureLayer? (In other words to actually be physically a part of the shapefile?) Isn't there a way to import a join's schema and data into the shapefile?
PriyankaMehta
   I am not too sure of what problem you are exactly facing, but I guess this might help. This code joins layer to layer
        Dim pFeatLayer As IFeatureLayer
        Dim pFeatLayerjn As IFeatureLayer
        Dim pDispTable As IDisplayTable
        Dim pFCLayer As IFeatureClass
        Dim pTLayer As ITable
        Dim pActiveView As IActiveView
        pMxDoc = My.ArcMap.Document
        pMap = pMxDoc.FocusMap
        pActiveView = pMap
        pMap.ClearSelection()
        pActiveView.Refresh()
        Dim pTLayer2 As ITable
        If pMap.LayerCount < 2 Then
            MsgBox("Must have at least two layer", MsgBoxStyle.Information)
            Exit Function
        End If
        pFeatLayerjn = FindLayerByName(pMap, LayerName)
        If pFeatLayerjn Is Nothing Then
            MsgBox("Could not find Layer " & LayerName & "for joining", MsgBoxStyle.Exclamation)
            Exit Function
        End If
        pDispTable = pFeatLayerjn
        pFCLayer = pDispTable.DisplayTable
        pTLayer = pFCLayer
        pFeatLayer = pMap.Layer(0)
        pTLayer2 = pFCLayer
        Dim strJnField As String
        Dim JnField2 As String
        strJnField = joinfield1           ''''''' FID
        JnField2 = joinfield2             ''''''' PntName
        ' Create virtual relate
        Dim pMemRelFact As IMemoryRelationshipClassFactory
        Dim pRelClass As IRelationshipClass
        pMemRelFact = New MemoryRelationshipClassFactory
        pRelClass = pMemRelFact.Open("LayertoLayer", pTLayer2, strJnField, pTLayer, JnField2, "forward", "backward", esriRelCardinality.esriRelCardinalityOneToOne)
        ' use Relate to perform a join
        Dim pDispRC As IDisplayRelationshipClass
pDispRC = pFeatLayer
pDispRC.DisplayRelationshipClass(pRelClass, esriJoinType.esriLeftOuterJoin)
        MsgBox("Fields Joined", MsgBoxStyle.Information)
Referring this one might also help
http://forums.esri.com/Thread.asp?c=93&f=992&t=97996&mc=3#msgid274992
Regards,
Priyanka
GeorgeFaraj
Regards,
Priyanka
Thanks! But isn't there a way to export a join to a feature class?  That is what I am searching for.  The Joined fields actually become part of the feature class.
