Need Help with Python Syntax
1582
9
02-24-2012 03:47 AM
AlanToms
Hello folks,
I need help with the proper syntax. I'm sure it's easy I just cant get it.  Basically it's telling me that the syntax for my return value, Str(!SHIELD_VAL!), is invalid.  I'm using a field calculator to run a check on field HWY_Type and given certain values, it will populate field FEDROUTE with the value of SHIELD_VAL.  Any help would be appreciated.
Thank you
Alan
def FedRoute(tvalue):     value = tvalue     if value == 'INT':         return Str(!SHIELD_VAL!)     elif value == 'US':         return Str(!SHIELD_VAL!)  FedRoute(!HWY_Type!)
LeonardWilliamson
Oops, I was testing the code and forgot to change the values to the original
LeonardWilliamson
Alan,
You need to include the SHIELD_VAL field as an input variable in order to read the values.  The code below should fix your problem.
def FedRoute(tvalue, shield):
    value = tvalue
    shield = ''
    if value == 5:
        shield = str(shield)
    elif value == 9:
    return shield
FedRoute(!HWY_Type!, !SHIELD_VAL!)
DarrenWiens2
Won't the above code result in an empty string, every time?
Instead:
    if tvalue == 'INT':
        return str(shield)
    elif tvalue == 'US':
        return str(shield)
LeonardWilliamson
AlanToms
I tried both examples (Leonard's modified to my data, Darrens' exaclty)  and they both returned the following error.  I looked up 'exceptions.SyntaxError' but I do not understand this enough to solve the issue.  Any other suggestions?  Thanks for the help on this. It is appreciated.
ERROR 000539: Error running expression: FedRoute("INT", "75
") <type 'exceptions.SyntaxError'>: EOL while scanning string literal (<string>, line 1)
Failed to execute (Calculate Field (FEDROUTE)).
DarrenWiens2
Did you choose Python as the parser?
AlanToms
Yes, I choose Python 9.3
LeonardWilliamson
Are "Int" and "US" the only values?
AlanToms
Yeah I seem to have NULL values in both the HWY_Type and SHIELD_VAL fields that I think is causing the problem.  I'll take a look at it again on Monday.
AlanToms
The code samples you both provided worked.  I discovered some issues with the data iteself that didnt want to work.
Thank you for the help.
Alan
