Rounding error when using constant raster
2388
02-22-2012 07:38 AM
JohnDoe1
I created a constant raster using the toolbox with value 1 (float)
I have the following python code:
a = (Raster('myRaster') * 1.724)
When I print the maximum/minimum of 'a', I get 1.72399997711
I also have a feeling that these rounding errors are causing some other problems in my script.
How can I fix this without manually rounding every operation?
DanPatterson_Retired
do a web search on floating point representation .  There is nothing you can do about it
JohnDoe1
I thought it would be  some numerical error, but I'm wondering why
a = 1.724
b = 1.0 * 1.724
print b #=1.724
does work, and my original code doesn't?
because of floating point representation
