Help with using definition query
1195
02-20-2012 11:26 PM
ClaireParsons1
Hi All
I'd like some help using definition query with layer.
Basically, I want to clip a raster several times by using polygons within a feature class. My idea was to use Searchcursor to loop through each row - set the definitionquery for the featureclass, clip the raster, delete the definitionquery then repeat.
Would this work?  Has anyone got any other ideas?
thanks
Claire
DuncanHornby
MVP Notable Contributor
Claire,
Instead of writing a Python script, why not use model builder? You could have a feature iterator that spews out a polygon one for each row (or even grouped by a case field) and this simply feeds into a clip raster tool as the clipping polygon?
Duncan
ClaireParsons1
Thanks for your reply - model builder is a good idea but it is part of a bigger script, so would prefer to have it in Python.
I've managed to sort it now and the definitionquery works!!:D
JeffBarrette
Have you tried the layer object via arcpy.mapping?
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Layer/00s300000008000000/
Once you reference a layer in a map document you can modify its query definition, for example:
mxd = arcpy.mapping.MapDocument(r"path/to/map.mxd")
lyr = arcpy.mapping.ListLayers(mxd, "some layer name")[0]
lyr.definitionQuery = "[query] = 'here'"
#Do you raster clip here
I'm not clear on your requirements but you may not even need to use a SearchCursor.  Simply change the def query in some sort of loop.
Jeff
ChrisSnyder
Honored Contributor
I didn't test this code, but it should work something like:
searchRows = arcpy.SearchCursor(myFC)
for searchRow in searchRow:
    myIdValue = searchRow.MY_FIELD_NAME
    outRaster = r"C:\temp\test_" + str(myIdValue)
    arcpy.MakeFeatureLayer_management(myFC, "fl", "MY_FIELD_NAME = " + str(myIdValue))
    arcpy.Clip_management(inputRaster, "", outRaster, "fl", "", "ClippingGeometry")
