joining  points to make a line
4755
5
02-14-2012 04:10 AM
KaziHaque
I am using ArcGIS  version 9.3 I have imported some boundary coordinates (x,y) in the map but  I would like to create boundary line by joining the boundary coordinates (points). I would be grateful if some body help me
AlexeyTereshenkov
You can try the Points to line GP tool which is available in ArcGIS 10: http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00170000003s000000.htm. It is available in all licenses.
First, add your XY coordinates as a point feature layer and add a sort field (optionally) which will be used for sorting.
Otherwise, there is a script which can be used (have not tested it with ArcGIS 10 though): http://arcscripts.esri.com/details.asp?dbid=12702
But the tool should do the work and you will be cool.
KaziHaque
I am using ArcGIS version  9.3 not version ArcGIS version 10 . Can you guide me how do I Convert point feature in to line feature by using ArcGIS  version 9.3.
AlexeyTereshenkov
There are lots of scripts available for ArcGIS 9.3 which could do that.
Start with: http://arcscripts.esri.com/details.asp?dbid=15945
More scripts to check:
http://arcscripts.esri.com/details.asp?dbid=15828 (this one seems to get many positive feedbacks, check it second)
http://arcscripts.esri.com/details.asp?dbid=12703
Hawth's tools could help you with converting the points to line:
http://www.spatialecology.com/htools/locstopath.php (download page: http://www.spatialecology.com/htools/download.php)
KaziHaque
Alex
Thank you very much the effort you have taken. But  now I realized that due to shallow knowledge  on ArcGIS  I don�??t have any ideas how to use script and what is script . I would be grateful to you guide me step by step  how to join  point feature  to make line feature.
Regards
michaelcollins1
Download ET Geowizards and use the point to polyline tool.
http://www.ian-ko.com/ET_GeoWizards/gw_main.htm
