RMS Error through code
1321
02-14-2012 03:00 AM
VinayanMP
I want to do a small spatial adjustment automation..it will be an affine transformation. I have generated the displacement links.
To set the transformation to affine i used the below code..
Dim pAdjust As esriEditorExt.IAdjustment Set pAdjust.CurrentTransformationMethod = pAdjust.TransformationMethod(0)
I plan to adjust the selected features by using the below method..
ThisDocument.CommandBars.Find("esriEditorExt.TransformCommand").Execute
I have two questions here
how do i know the existing RMS error for the existing links programmatically?
how do i set the features to be adjusted as selected features?
Any help is greatly appreciated..
by Anonymous User
Not applicable
Vinayan,
You can get the RMS errors through the ITransformationMethodRMSError Interface
You can set 'adjust selected features' via the IAdjustLayers Interface
by Anonymous User
Not applicable
Vinayan,
VinayanMP
Hi Sean,
Your solution worked like a charm..i spent around 2 hrs searching for a solution..thank you..below is my working code..
Dim pTransformMethod As ITransformationMethod
Set pTransformMethod = pAdjust.CurrentTransformationMethod
Dim pTransformMethodRMS As ITransformationMethodRMSError
Set pTransformMethodRMS = pTransformMethod
Dim rmsError As Double
pTransformMethodRMS.GetRMSError rmsError
MsgBox rmsError
