Hello,I would like to make a Geoprocessiong Service in ArcGIS Server thats extracts data with a polygon. I have a copy of Extract Data Task and I personalized it. Instead of make a clip as does the original, I have a SelectByLocation and after a CopyFeatures function. I don't want to clip but to extract features that intersects by the polygon. This is the function I modified (original clip function is commented):
def clipFeatures(lyr, aoi, featureFormat, zipFolderPath, scratchFolderPath, convertFeaturesDuringClip):
global haveDataInterop
try:
## if not convertFeaturesDuringClip and not haveDataInterop:
## raise "LicenseError"
# get the path and a validated name for the output
layerName, outputpath = makeOutputPath(False, lyr, convertFeaturesDuringClip, featureFormat, zipFolderPath, scratchFolderPath)
# do the clip
#gp.clip_analysis(lyr, aoi, outputpath)
gp.SelectLayerByLocation_management(lyr, 'intersect', aoi)
gp.CopyFeatures_management(lyr, outputpath)
#Message " clipped %s..."
gp.AddMessage(gp.GetIDMessage(86135) % lyr)
# if format needs data interop, convert with data interop
if not convertFeaturesDuringClip:
# get path to zip
outputinzip = os.path.join(zipFolderPath, layerName + featureFormat[2])
if featureFormat[2].lower() in [".dxf", ".dwg", ".dgn"]:
gp.AddWarning(gp.GetIDMessage(86139))# "..using export to cad.."
gp.ExportCAD_conversion(outputpath, featureFormat[1], outputinzip)
else:
if not haveDataInterop:
diFormatString = "%s,%s" % (featureFormat[1], outputinzip)
# run quick export
gp.quickexport_interop(outputpath, diFormatString)
except "LicenseError":
#Message " failed to export to %s. The requested formats require the Data Interoperability extension. This extension is currently unavailable."
gp.AddWarning(gp.GetIDMessage(86140) % featureFormat[1])
pass
except:
errorstring = gp.GetMessages(2)
if errorstring.lower().find("failed to execute (quickexport)") > -1:
#Message " failed to export layer %s with Quick Export. Please verify that the format you have specified is valid."
gp.AddWarning(gp.GetIDMessage(86141) % lyr)
elif errorstring.lower().find("failed to execute (clip)") > -1:
#Message " failed to clip layer %s...
gp.AddWarning( gp.GetIDMessage(86142) % lyr)
else:
gp.AddWarning(gp.GetIDMessage(86142) % lyr)
gp.AddWarning(gp.GetMessages(2))
pass
When I executed the function in ArcMap with the dialog, the task works fine. The layers are not clipped. The problem comes when I publish the same service with the Geoprocessing Service. When I test it in ArcGIS Service Directory page, the resulting zip contains layers clipped, when the function I personalized is the same.I don't understand this, when the task is the same in the Toolbox and the task published as a geoprocessing service.Does anyone know what happens?ThanksPau Pérez PuigcerverConselleria de Infraestructuras, Territorio y Medio Ambientehttp://cartoweb.cma.gva.es
