Unable to use Application.Hyperlink in ArcMap?
748
02-06-2012 03:02 AM
HalilSiddique
Hi all,
In my application i have a text box which is populated with a weblink, I have found some code which "should" allow me to click on it and open the link, but I get the following error
"438: Object doesn't support this property of method".
Is it not possible to use hyperlinks?
This is the code i am using for that text box.
Private Sub txtDeveloperWebsite_MouseDown(ByVal Button As Integer, ByVal Shift As Integer, ByVal X As Single, ByVal Y As Single)    Dim strDevWebsite As String    On Error GoTo Error_OLEUnbound1    ' Set reference to hyperlink address.    strDevWebsite = txtDeveloperWebsite.Text    ' Follow hyperlink address.    Application.FollowHyperlink strDevWebsite, , True Exit_OLEUnbound1:    Exit Sub Error_OLEUnbound1:    MsgBox Err & ": " & Err.Description    Resume Exit_OLEUnbound1 End Sub
I'm using ArcGIS 9.3.1
DuncanHornby
MVP Notable Contributor
Halil,
Looking at your sample code I believe the sample you have found is specific to MS Access. If you want to open a website using VBA in ArcMap 9.3 use this code instead:
Dim iE As Object Set iE = CreateObject("InternetExplorer.Application") iE.navigate "www.rivex.co.uk" iE.Visible = True
Duncan
DuncanHornby
Halil,
Duncan
HalilSiddique
Halil,
Dim iE As Object
iE.Visible = True
Duncan
Perfect, thanks Duncan.
