Python Script to Tool in Custom Toolbox
5021
13
01-31-2012 08:04 AM
BrittneyVenetucci
Hi all,
I am trying to create a tool from a script that repairs all broken data sources in an mxd. I have posted the code as follows:
import arcpy, os
PYTHONPATH = "C:\Python26\ArcGIS10.0\lib\ntpath.pyc"
folderpath = arcpy.GetParameterAsText(0)
oldpath = arcpy.GetParameterAsText(1)
newpath = arcpy.GetParameterAsText(2)
print 'running'
i=0
#create a folder within a local folder to store the mxds
folderPath = r""
for filename in os.listdir(folderPath):
    fullpath = os.path.join(folderPath, filename)
    if os.path.isfile(fullpath):
        basename, extension = os.path.splitext(fullpath)
        if extension.lower() == ".mxd":
            mxd = arcpy.mapping.MapDocument(fullpath)
            oldpath = ""
            newpath = r""
            #mxd.replaceWorkspaces(oldpath, "SDE_WORKSPACE", newpath, "SDE_WORKSPACE",True)
            print "ok"
            mxd.findAndReplaceWorkspacePaths(oldpath, newpath)
            #mxd.save()
            mxd.save()
        print '...', basename, extension, "finished"
However, when I run the tool it does not work. Any ideas as to what I have to set my input parameters as or if there is something wrong in my code?
Thanks!
Brittney
MathewCoyle
Honored Contributor
This line may cause issues.
Should be as below, if you ave to include it at all.
PYTHONPATH = r"C:\Python26\ArcGIS10.0\lib\ntpath.pyc"
You can see this link for help and repairing data sources.
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00s30000004p000000
To format your post correctly, read this.
http://forums.arcgis.com/threads/48475-Please-read-How-to-post-Python-code
BrittneyVenetucci
Ok I got the tool to work but it is not saving the mxds.. am I missing a variable?
Brittney
MathewCoyle
Honored Contributor
I would try this
mxd.saveACopy(file_name, {version})
curtvprice
PYTHONPATH is a Windows (or UNIX) environment variable that needs to be set before the script is run, if you need it. The purpose of that variable is to modify sys.path when Python launches. Sys.path is a list of folders that tells Python where to look for imports, ie "import mymodule" will look for a file "mymodule.py" or "mymodule.pyc" through the sys.path, and use the first one it finds.
It looks like you are trying to invoke the ntpath module. This module is already in the sys.path, so you could get to it with:
import ntpath
However, you don't need to import it -- the os module is what you want (and what you are using).  I'm pretty sure os calls ntpath for you on windows, something else on Mac or Unix.
If you need to alter where to look at runtime, you can alter the sys.path as follows.
import sys
sys.path.append(r"C:\mytools\python\modules")
You can check out where imports will look by listing your sys.path:
>>> import sys
>>> sys.path
Note, by default, "" is the first item in sys.path. So if you include a custom module in the same folder as the script, it will always use that version.
http://docs.python.org/tutorial/modules.html
BrittneyVenetucci
[/HR]
I would try this
I had this originally in my code, but I simply just want to update the existing mxd's. (Since I will be running the tool multiple times to repair multiple sde databases within a single mxd.)
Do I need to create a derived variable? If so, where/how would I call this out in my code?
Any help would be greatly appreciated.
MathewCoyle
Honored Contributor
What is the particular error you are getting? Or does it run through without error and just not make any changes to the mxd?
Also, posting your code with code blocks will make it easier for us to help.
BrittneyVenetucci
I am not getting an error, rathre it is nto saving my mxds
BrittneyVenetucci
import arcpy, os
print 'running'
i=0
folderPath = r""
oldpath = ""
newpath = r""
print "ok"
#mxd.save()
mxd.save()
BrittneyVenetucci
I have reposted my code. Does anyone have any ideas on why it is not wiriting over my mxd's? It works as a standalone script, but not as a tool in a toolbox.
Brittney
