Is Java still supported?Yes.
Is there updated eclipse plugin to download?Use the one from the ArcGIS installation directory.
Eclipse Visual Editor was only needed to do visual drag/drop of ArcEngine components, and you are correct in that the Eclipse VI project is retired. However, you can still download that project and use it with Eclipse 3.6.(something - I forget).
Yes.
Although not supported by ESRI, Eclipse Java Indigo 3.7.1 will work fine with the plugin from the ArcGIS installation directory, you just don't get the visual drag/dop stuff for ArcEngine map controls, toc controls, etc.
All of the configuration is clearly in the ArcObjects Project code, if you wanted to change it.
