arcpy.NumPyArrayToRaster cont.
4420
5
01-24-2012 06:53 PM
SarahBurns
I am still having difficulties converting a numpy array to a raster.
I have created a raster for my cell sizes and have found the latitude min and longitude min for the lower_left_corner and use the following code:
from numpy import *
myarray=genfromtxt("E:/test/rasterise/myfile.txt")
mylon=genfromtxt("E:/test/rasterise/LATout.txt")
mylat=genfromtxt("E:/test/rasterise/LONout.txt")
corner=arcpy.Point(139.8, -39.2)
myRaster=arcpy.NumPyArrayToRaster(myarray, corner, mylon, mylat)
but I receive an error message:
Runtime error <type 'exceptions.TypeError'>: Argument x_cell_size: Expected a numeric value, Raster instance or path name.
however the documentation says that you can use a raster for the cell size. Not sure where I am going wrong here.
Any feedback will be greatly appreciated.
curtvprice
By "raster" I believe they mean an ArcGIS-recognized raster dataset or raster band, not a numpy array.
ChrisBater
I've been struggling with this as well. My work-around has been to use gdal. However, if I'm forced to use arcpy, then I crank out the array as a raster with no spatial reference, then use "rescale," "shift," and "define projection" to put the final surface back to where it should be. I wrote a function to do this, but it's definitely not optimal. There needs to be a better, more in depth usage example included in the numpyarraytoraster tool's help doc.
SarahBurns
It sounds like I will need to spend some time working out how to do this in GDAL....
thanks for the replies!
ChrisBater
This might help get you started with gdal....
Based on code I found here: http://www.gis.usu.edu/~chrisg/python/
program: TOA to NDVI.py
Chris Bater
GIS and Remote Sensing Technologist
Wildfire Resource Information Unit
Wildfire Management Branch
Forestry Division
Alberta Sustainable Resource Development
9th floor Great West Life Building
9920 - 108 Street
Edmonton, AB
T5K 2M4
Ph: 780-422-0669
Cell: 780-446-1899
Email: [email protected]
Date: September 2011
Purpose: Converts Landsat-5 TOA reflectance data to NDVI
#Identify the directory containing the landsat data
workspace = r"C:\_LOCALdata\temp"
#Import and load modules
# Import system modules
import os, sys
from osgeo import gdal
import numpy as np
import numpy.ma as ma
#register the GDAL drivers
gdal.AllRegister()
driver = gdal.GetDriverByName('GTiff') #not sure if this is necessary
driver.Register()#not sure if this is necessary
print ""
print "All systems go"
print "Hit CTRL + c at any time to stop processing"
print ""
#Iterate through the landsat scenes and convert to TOA
try:
    files = os.listdir(workspace)
    for f in files:
        if not f.endswith('tif'):
            continue
        name = f[:-4]
        #open the landsat TOA file
        TOA = gdal.Open(workspace + "/" + f)
        #get the image size
        rows = TOA.RasterYSize
        cols = TOA.RasterXSize
        bands = TOA.RasterCount
        if bands != 6:
            continue
        print "processing " + f
        #create an empty tif file
        outData = driver.Create(os.path.join(workspace, name + "_NDVI.tif"), cols, rows, 1, gdal.GDT_Float32)
        outBand = outData.GetRasterBand(1)
        #assign the bands to variables
        b3 = TOA.GetRasterBand(3)
        b4 = TOA.GetRasterBand(4)
        #set the initial blocksize for analysis
        xBlockSize = 5000
        yBlockSize = 5000
        for i in range(0, rows, yBlockSize):
            if i + yBlockSize < rows:
                numRows = yBlockSize
            else:
                numRows = rows - i
            for j in range(0, cols, xBlockSize):
                if j + xBlockSize < cols:
                    numCols = xBlockSize
                else:
                    numCols = cols - j
                #read bands into arrays
                d3 = b3.ReadAsArray(j, i, numCols, numRows).astype(np.float32)
                d4 = b4.ReadAsArray(j, i, numCols, numRows).astype(np.float32)
                #mask no data values (no data = 0)
                m3 = ma.masked_equal(d3, 0)
                m4 = ma.masked_equal(d4, 0)
                del d3, d4
                ndvi = (m4 - m3) /(m4 + m3)
                del m3, m4
                outBand.WriteArray(ndvi, j, i)
        # flush data to disk, set the NoData value and calculate stats
        outBand.FlushCache()
        outBand.SetNoDataValue(0)
        stats = outBand.GetStatistics(0, 1)
        # georeference the image and set the projection
        outData.SetGeoTransform(TOA.GetGeoTransform())
        outData.SetProjection(TOA.GetProjection())
        #memory management
        del TOA, outData, outBand
    print 'script complete'
except Exception, e:
    # If an error occurred, print line number and error message
    tb = sys.exc_info()[2]
    print "Line %i" % tb.tb_lineno
    print e.message
SarahBurns
excellent thanks, that helps alot!
