Fill in NoData values
9533
8
01-23-2012 09:43 AM
BarryGuidry
I have created an ESRI grid from LIDAR data, after first processing grids in Surfer. But, based on the spacing I specified in Surfer, there are gaps (NoData) in the ESRI grid created from the "ground-surface" returns, due to the building locations (in the unclassified return). Can someone help me figure out how to fill in these gaps (of NoData), likely with the "nearest neighbors"?
TimothyHales
Esri Notable Contributor
Check out this forum thread: Raster Calculator: Fill in NoData. It discusses using the Raster Calculator to fill the gaps.
ArcGIS 9.3.1
con(isnull(Raster_DEM), focalmean(Raster_DEM, rectangle,4,4), Raster_DEM)
ArcGIS 10
Con(IsNull(Raster), FocalStatistics(Raster, NbrCircle(10, "CELL"), "MEAN"), Raster)
JohannaPrüssmann
I tried Timothy Hales' algorithm in ArcGIS 10.1 for fillind NoData holes in my DEM, but I get the following error message:
Executing: RasterCalculator Con(IsNull("Tecbaco_DEM.tif"), FocalStatistics(Raster, NbrCircle(10, "CELL"), "MEAN"), "Tecbaco_DEM.tif") "C:\Users\HOME\Copy\- WWF\- TECBACO\DEM v.2\Tecbaco_DEM_Fill.tif"
Start Time: Mon Feb 02 19:36:05 2015
Con(IsNull(Raster(r"Tecbaco_DEM.tif")), FocalStatistics(Raster, NbrCircle(10, "CELL"), "MEAN"), Raster(r"Tecbaco_DEM.tif"))
ERROR 000539: Error running expression: rcexec()
  File "<expression>", line 1, in <module>
  File "<string>", line 5, in rcexec
  File "c:\program files (x86)\arcgis\desktop10.1\arcpy\arcpy\sa\Functions.py", line 4830, in FocalStatistics
    ignore_nodata)
  File "c:\program files (x86)\arcgis\desktop10.1\arcpy\arcpy\sa\Utils.py", line 47, in swapper
    result = wrapper(*args, **kwargs)
  File "c:\program files (x86)\arcgis\desktop10.1\arcpy\arcpy\sa\Functions.py", line 4824, in wrapper
    ignore_nodata)
  File "c:\program files (x86)\arcgis\desktop10.1\arcpy\arcpy\geoprocessing\_base.py", line 484, in <lambda>
    return lambda *args: val(*gp_fixargs(args, True))
RuntimeError: Object: Error in executing tool
Failed to execute (RasterCalculator).
Failed at Mon Feb 02 19:36:05 2015 (Elapsed Time: 0.00 seconds)
I used the following algorithm:
Do you have any idea why this might be happening?
XanderBakker
Esri Esteemed Contributor
You should replace "Raster" by your TIFF:
Con(IsNull("Tecbaco_DEM.tif"), FocalStatistics("Tecbaco_DEM.tif", NbrCircle(10, "CELL"), "MEAN"), "Tecbaco_DEM.tif")
JohannaPrüssmann
Thanks for the quick response. I'm sorry, I did not notice the second "raster" instance. I will try once again and let you know how it goes.
JohannaPrüssmann
Yep, it worker wonderfully. Thanks for your help!
XanderBakker
You're welcome. Glad it worked!
DanPatterson_Retired
You will have better results if you convert to an Esri grid for both the inputs and the outputs in a folder with no spaces and a shorter file name.  In theory you should be able to use any raster, but I notice many of the issues revolve around 'image' rasters which may be multiband and may not play nicely with many of the SA functions
JohannaPrüssmann
Thanks for the advice. Will do.
