create and update feature class
761
01-20-2012 04:36 PM
suhanatssuhanats
I have a python script to create featureclass from an sql server database table
the sql table gets updated everyday. So i want to find the max(id) from featureclass and select only those newer rows in sql table where id
greater than featureclass id and update it to feature class.
JakeSkinner
Esri Esteemed Contributor
Hi Suhanats,
You can find the max OBJECTID by appending the OIDs to a list and then retrieving the max value from the list.  Ex:
fc = "Airports"
OID_list = []
rows = arcpy.SearchCursor(fc, "", "", "OBJECTID")
for row in rows:
    OID_list.append(row.OBJECTID)
del row, rows
maxOID = max(OID_list)
Next you can use maxOID variable to select only the new records within the SQL table.
RussellBrennan
There is a Summary Statistics tool in the analysis toolbox that will get you to get the max value for a field and output this value to a new table.
suhanatssuhanats
thank you. i did a sort desc in the cursor and got the value of the field. i had to do this since the id value that i want is not the standard objectid field, but a user created field.
