Migrate VBA directly to Add-Ins or VBA to VB.NET then to Add-Ins
1188
01-19-2012 12:42 PM
RobertHanover
Dear ArcObjects Developers,
I have to migrate several 9.3 applications from VBA to 10.0 Add-Ins.  Is it easier to migrate to VB.NET first and then to Add-Ins?  Or, should I go straight from VBA to Add-Ins?
Thank You,
Robert Hanover
Ohio Dept. of Natural Resources
RichardFairhurst
Thank You,
Robert Hanover
I am going straight to Add-Ins.  I am checking out whether an Add-In button can be used with stamdard Windows forms.  According to ESRI support I am supposed to be able to do that.  In any case, Add-Ins have some limitations, but they simplify deployment, so they are attractive if you have to distribute your tools.
JeffreyHamblin
Hello Robert,
The easist option, imo, is VBA to Add-In. You can code the Add-In in VB.NET, C#, or JAVA.
A year ago I put together a tutorial on converting a simple VBA 9.3 ArcMap utility that included a button that launches a form and performs a simple move features operation. It converts the VBA to a C# Add-In, but the process for VB.NET is very similar and with less changes needed to go from VBA to VB.NET.
VBA to Add-In Conversion Tutorial
