Doing multiple queries with a loop
3816
12
01-18-2012 09:10 AM
julienhubert
Hello everyone !
I work on ArcGIS 9.3 and I'd want to execute many queries in a row with Python.
Actually I have a layer, called "lines" that contains all the bus lines of a city. And my question is : how to save each line in a different layer ?
I thought the best thing to do would be :
- a query by attributes : field used : "blines". Characterizes the number of the lines (1, 2, 3 and so on)
- and then to save each query in a distinct layer
A good solution would be a loop in order to make the computation faster but I don't really know how to do.
I tried to make that script but I guess I'm very far from the right result :
import sys, string, os, arcgisscripting
gp = arcgisscripting.create(9.3)
gp.AddToolbox("C:/Program Files (x86)/ArcGIS/ArcToolbox/Toolboxes/Data Management Tools.tbx")
# Variables in local
lines_shp = "d:\\Travaux\\NantesMetropole\\lines.shp"
test = ["blines"]
while 1:
    for i in test:
        try:
            gp.Select_analysis(lines_shp, i_shp, i)
            print "Query successful"
        except:
            print "Error"
    break
Have you got any ideas ?
Thank you !
Julien
DarrenWiens2
You can adapt this to suit your needs:
import arcpy
fc = "d:/Travaux/NantesMetropole/lines.shp" # path to input feature class
field = "blines" # field name to get unique values
arcpy.MakeFeatureLayer_management(fc, "lyr") # make feature layer
rows = arcpy.SearchCursor(fc, "", "", "", field) # make cursor, sort by field
firsttime = 1
prev = -1
for row in rows: # loop through each feature
    current = row.getValue(field) # get current field value
    if firsttime == 1 or prev != current:
        prev = row.getValue(field) # set prev to current value
        arcpy.SelectLayerByAttribute_management("lyr", "NEW_SELECTION", field + " = " + str(row.mapnumber))
        arcpy.CopyFeatures_management("lyr", "d:/Travaux/NantesMetropole/lines" + str(current) + ".shp")
arcpy.Delete_management("lyr")
del row
del rows
julienhubert
Thanks for your reply.
I tried your code in my script "test_rte.py" (adapting it by using arcgisscripting instead of acrpy) but I have an error message :
  File "C:\_basedata_arcgis\test_rte.PY", line 14, in <module>
TypeError: 'geoprocessing cursor object' object is not iterable
What could I do to correct this ?
Thanks for the help.
DarrenWiens2
Oh, sorry - didn't see you're on 9.3. Arcpy only works on 10. You can basically use the same script format, just substitute arcgisscripting for arcpy and create the geoprocessor object as you did above.
DarrenWiens2
In arcgisscripting, I think you need to add the line
row = rows.next()
between creating the SearchCursor and the loop. You also need to add that line to the very end of the loop to advance the cursor. See this help page to see an example.
julienhubert
Yeah it's right, I corrected it and it looks good....
... but another new error message :
    gp.SelectLayerByAttribute_management("lyr", "NEW_SELECTION", field + " = " + str(row.mapnumber))
RuntimeError: Row: Field mapnumber does not exist
What exactly is the row.mapnumber function ? I took a look in both the python docs and the arcgis help but it's not explained..
DarrenWiens2
Sorry, "mapnumber" was the field I tested the script with (I thought I changed them all). You can change str(row.mapnumber) to str(current).
julienhubert
Ok thanks for row.mapnumber !
So new try and there is an error on the execution of SelectLayerByAttribute :
    gp.SelectLayerByAttribute("lyr", "NEW_SELECTION", field + " = " + str(current))
ExecuteError: ERROR 000358: Invalid expression
Failed to execute (SelectLayerByAttribute).
DarrenWiens2
It works for me. Instead of: gp.SelectLayerByAttribute("lyr", "NEW_SELECTION", field + " = " + str(current))
try:
expr = field + " = " + str(current)
gp.SelectLayerByAttribute("lyr", "NEW_SELECTION", expr)
julienhubert
Ok, I tried many and many things including your last advice but it still does not work.
I don't want to waste your time but could you write the entire code (since it works for you) ?
