Difference between standard deviation from attribute and from properties
1062
01-11-2012 12:29 AM
SergeRafanoharana
Dear All,
v. ArcGIS 9.3
I would like to know what is the difference between the standard deviation in the attribute (Right click on the attribute name -> Statistics) and the standard deviation from the layer properties (Properties -> Symbology -> Classified -> Choose Field Value -> Classify -> Classification Statistics)
So if one asks me to give the standard deviation, let's say of my temperature data (raster), which one should I provide?
Thank you,
Sypou
DanPatterson_Retired
I would first confirm that there are no NoData values in the field, then use the field statistics option.  You should also note that the population standard deviation is returned and not a sample standard deviation.  Should you require other statistical parameters, and you are using ArcGIS 10, then see
http://resources.arcgis.com/gallery/file/geoprocessing/details?entryID=BDF21676-1422-2418-34E6-A29C6...
after querying for valid data entries.
SergeRafanoharana
Thank you for your answer... As I stated in my previous message, I use v ArcGIS 9.3...
I found out that in the Properties -> Source -> Statistics, we also have the statistics...
Anyway thank you.
