Export Dojo Datagrid Results to .csv File?
13654
23
01-09-2012 05:50 AM
EmilyLaMunyon
Does anyone have advice on how to export the contents of a dojo.datagrid to a .csv file or excel spreadsheet? I am needing this function in my Javascript API web mapping application.
Thanks!
KellyHutchins
Esri Notable Contributor
I haven't tested this but it looks like the following sample from ArcScripts may do what you need:
http://arcscripts.esri.com/details.asp?dbid=16528
DeanSeales
I there an updated version of that sample?
GeorgeSimpson
You could also look at using the dojox.grid.EnhancedGrid which has "plugins" that can export to various formats
EmilyLaMunyon
Has anyone had luck exporting a dojo datagrid to a csv file? The example above is a bit outdated and I am having trouble getting it to work.:confused:
Thanks!
HemingZhu
Thanks!
There is a python script in http://resources.arcgis.com/gallery/file/geoprocessing/details?entryID=95009B25-1422-2418-7FB5-B8638.... You can easily modify it and use it as a GP Service. I personally used it to convert  a query results (FeatureSet) to CSV or .XLS file.
EmilyLaMunyon
Thanks again for your help!!
Do you know if this script works for a Dojo datagrid?
HemingZhu
Yes, basically the data store for datagrid is either the query, find or identify featureset. I used the script in a Windows Phone 7 app where i convert a query result FeatureSet to csv or .xls based on user choice.
EmilyLaMunyon
I am getting close. The problem is that only one result, the last one, from my datagrid is showing up in my text area for export to excel. I think the csv is not getting the full results from the feature selected, for some reason it only gets one. How do I get the full results of the selection ready for csv export?
function executeIdentifyTask(geom) {
      //clear the graphics layer
      map.graphics.clear();
      identifyParams.geometry = geom;
      identifyParams.mapExtent = map.extent;
      identifyTask.execute(identifyParams,function(response){
  var polygonSymbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([98,194,204]), 2), new dojo.Color([98,94,204,0.8]));
        var markerSymbol = new esri.symbol.SimpleMarkerSymbol().setColor(new dojo.Color([25,50,225,0.3]));
         var controlItems = [];
         var surveyItems = [];
         dojo.forEach(response,function(result){
         var feature = result.feature;
        if (result.layerName =="surveys"){
     showSurveysNameGrid();
                 feature.setSymbol(polygonSymbol);
      var attributes = feature.attributes;
                  surveyItems.push(attributes);
      var csvTextSurv = "DOCUMENT_N;TOWNSHIP_RANGE;SECTION\n";
  csvTextSurv += attributes["DOCUMENT_N"] + ";" +
                               attributes["TOWNSHIP_RANGE"] + ";" +
                               attributes["SECTION"] + "\n";
         document.getElementById("csvSurv").value = csvTextSurv;
         map.graphics.add(feature);
    }else{
      showPointNameGrid();
  feature.setSymbol(markerSymbol);
  controlItems.push(feature.attributes);
  var csvTextMons = "POINT_NAME;SECTION\n";
  csvTextMons += attributes["POINT_NAME"] + ";" +
      document.getElementById("csvMons").value = csvTextMons;
         if(surveyItems.length >0){
            var surveysStore = new dojo.data.ItemFileReadStore({data:{identifier:'DOCUMENT_N',items:surveyItems}});
            var grid = dijit.byId('grid5');
            grid.setStore(surveysStore);
  if(controlItems.length >0){
     var controlStore = new dojo.data.ItemFileReadStore({data:{identifier:'POINT_NAME',items:controlItems}});
     var grid = dijit.byId('grid4');
        grid.setStore(controlStore);
      <div id="footerPoints" class="roundedCorners" dojotype="dijit.layout.ContentPane"  region="bottom"  style=" padding-bottom:5%; height:18%; display:none">
      <form action="http://surveyor.slco.org/JSAPIExportToExcel/DojoGridToExcel.asmx/CSV2Excel " method="POST">
    <textarea name="csv" id="csvMons" style="width: 500px; height:30px"></textarea>
    <input type="submit" value="Submit" />
    </form>
          <table dojotype="dojox.grid.DataGrid" data-dojo-id="grid4" id="grid4" data-dojo-props="rowsPerPage:'5', rowSelector:'20px'">
   <thead>
              <tr>
 <th field="POINT_NAME"  width="200px"  >
                Point Name
               </th>
                <th field="GRID_ADDRESS" width="200px"  >
                  Address
                </th>
    <th field='TOWNSHIP_RANGE' width='200px'>Township/Range</th>
                <th field="SECTION" width="200px" >
                 Section
                </th>
  <th fields="POINT_NAME,LONGITUDE_DD,LATITUDE_DD" formatter="makeLink1" width="200px" >
                  Monument Reference Sheet
                </th>
              <th field="MON_NOTES" width="200px" >
                  Monument Notes
                </th>
            </tr>
            </thead>
          </table>
        </div>
       <div id="footersurvName" class="roundedCorners" dojotype="dijit.layout.ContentPane"  region="bottom"  style=" padding-bottom:5%; height:18%; display:none">
    <textarea name="csv" id="csvSurv" style="width: 500px; height:30px"></textarea>
    </form>
          <table dojotype="dojox.grid.DataGrid" data-dojo-id="grid5" id="grid5" data-dojo-props="rowsPerPage:'5', rowSelector:'20px'">
        <thead>
        <tr>
      <th field="DOCUMENT_NUM" width="200px" >
       Survey Number
       </th>
       <th field="SURVEYOR"  width="200px"  >
        Surveyor
        </th>
         <th field="ADDRESS_OF_SURVEY" width="200px"  >
          Address
         </th>
        Township/Range
        </th>
                 Section
         </th>
         <th fields="subdir,page_id" formatter="makeLink" width="200px" >
                  PDF
                </th>
              </tr>
            </thead>
          </table>
        </div>
MattMoyles
A CSV output is possibly the simplest you could have. Take the datastore backing your grid. Query it. Loop the results, and concatenate a new line to some output variable. Post the data to a server-side script. (PHP or ASP.NET) that will write your data to a file and then redirect the user's browser to download the .csv file.
Here's some javascripty psedo-code.
itemStore //data store backing your grid
var queryResults = itemStore.query();
var output = '';
dojo.forEach(queryResults, function(result) {
    output = output + '\n' + result['col1'] + ',' + result['col2'] + ',' + result['col3'] + and so on...
xhr.post(/*post to some serverside script*/);
xhr.onSuccess(/*redirect them to download the file*/);
Piece of cake.
EDIT: Here found this for ya too. http://stackoverflow.com/questions/4440803/exporting-a-dojo-datagrid-to-a-csv-file
