Edit Attributes in User Form
1478
8
01-05-2012 04:53 AM
PhyllisDavis
I am trying to convert my old ArcGIS 9.3 (VBA) code to ArcGIS 10 using Visual Basic 2008 Express Edition. So far I have sucessfully created an pop-up window that displays the attributes of a selected feature in text boxes on the form.
However, I want to create a button that allows users to save any changes they make to the attributes in the user form. Below is the code I have thus far for the On_Click event to update the attributes.
The error I'm getting is on "IEditor.EditState <> esriStateEditing Then" IT says reference to non-shared member requires an object reference
Private Sub cmdUpdate_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles cmdUpdate.Click
    Dim pMxDoc As IMxDocument
    pMxDoc = My.ArcMap.Document
    Dim pMap As IMap
    pMap = pMxDoc.FocusMap
    Dim pFLayer As IFeatureSelection
    Dim Count As Integer
    For Count = 0 To pMap.LayerCount - 1
        'Get the Transportation Improvement Line Layer from the Map
        If pMap.Layer(Count).Name = "TransportationImprovementProjects_Lines" Then
            pFLayer = pMap.Layer(Count)
            Dim pFCursor As IFeatureCursor = Nothing
            pFLayer.SelectionSet.Search(Nothing, False, pFCursor)
            Dim pF As IFeature
            pF = pFCursor.NextFeature
        End If
        'Get Dataset from FeatureLayer
        Dim pEditDataset As IDataset
        pEditDataset = pFLayer
        'If not editing, start editing dataset's Workspace
        If IEditor.EditState <> esriStateEditing Then
            Editor.StartEditing(pEditDataset.Workspace)
        End If
        'Initialize first (only) feature
        Dim pFeat As IFeature
        pFeat = pFLayer.NextFeature
        'Update attributes with user input
        pFeat.Value(pFeat.Fields.FindField("YEAR")) = txtPrjYear.Text
        pFeat.Value(pFeat.Fields.FindField("PROJECTYPE")) = txtPrjType.Text
        pFeat.Value(pFeat.Fields.FindField("LOCATION")) = txtLocation.Text
        pFeat.Value(pFeat.Fields.FindField("AGENCY")) = txtAgency.Text
        pFeat.Value(pFeat.Fields.FindField("DESCRIPTION")) = txtDescrip.Text
        pFeat.Value(pFeat.Fields.FindField("COST")) = txtCost.Text
        pFeat.Value(pFeat.Fields.FindField("DATEEDITED")) = txtDate.Text
        pFeat.Value(pFeat.Fields.FindField("USEREDITED")) = txtUser.Text
        'Store changes to feature
        pFeat.Store()
        'Stop editing and save edits
        Editor.StopEditing(True)
        'Refresh map
        pMxDoc.ActiveView.Refresh()
        'Close form
        Me.Close()
    Next Count
End Sub
NeilClemmons
Honored Contributor
The variable you are using to reference the editor is named Editor, not IEditor.  Or at least I think it is.  I don't see where you are declaring it or setting its value.  Change IEditor to Editor and it should work.
PhyllisDavis
Ahh...thanks, Neil..
Ahh...thanks, Neil!!
I added "Public Editor as Editor", Instantiated the EditorDim Editor = My.ArcMap.Document.FindExtensionByName("ESRI Object Editor"), and changed all my IEditors to Editor.
However, it crashes everytime i push the button....any suggestions?!?
        Dim pMap As IMap
        'Instantiate the editor
            Dim pF As IFeature
            If Editor.EditState <> Editor Then
            End If
            pFeat.Store()
            'Close form
            Me.Close()
        End If
    End Sub
NeilClemmons
Honored Contributor
You're declaring Editor twice.  You should only be declaring it once.  If you want the variable to be module level then keep the Public declaration and remove the Dim.  The line should be:
If you want the variable to have local scope then remove the Public declaration and edit local declaration to include the data type:
Dim Editor As IEditor = My.ArcMap.Document.FindExtensionByName("ESRI Object Editor")
Also, this line is incorrect:
You should replace Editor with an EditState enumeration value.
You should also put your edits inside of an edit operation, which I don't see in your code.
PhyllisDavis
Neil, Thanks again for your help...as you can tell I'm very much a novice with programming.  I spent a lot of time yesterday trying to figure out how to get this code to work, but each time it crashes when the button is clicked. I added "editor.startediting(peditdataset.workspace)" within the code and removed the public editor declaration.
Am I selecting my feature in correctly or am I still mis-coding my editor?
        Dim pMap As IMap
        'Get a reference to the editor
        Dim uid As UID
        uid = New UIDClass()
        uid.Value = "esriEditor.Editor"
        Dim editor As IEditor
        editor = My.ArcMap.Document.FindExtensionByName("ESRI Object Editor")
        If editor.EditState <> esriEditState.esriStateEditing Then Exit Sub
            Dim pF As IFeature
            'Start Editing
            editor.StartEditing(pEditDataset.Workspace)
            pFeat.Store()
            'Close form
            Me.Close()
        End If
    End Sub
NeilClemmons
Honored Contributor
There are several things I would change in your code.
1)  You declare and set the variable uid but then never use it.  I would get rid of it or change the call to FindExtensionByName to FindExtensionByCLSID and use it.
2)  You're checking the editor's Edit State and exiting if an edit session is not already started.  Therefore, you shouldn't attempt to start an edit session later in the code.  Remove that call to start the edit session.
3)  You're declaring pFCursor, filling it from the selection set and getting the first feature from it.  You then do not use it for anything.
4)  pFeat = pFLayer.NextFeature  I'm not sure how you don't get a compile error here.  IFeatureSelection doesn't have a NextFeature method.  I would get rid of this and use the feature you got from pFCursor earlier.
5)  Make sure all of those field names are spelled correctly.  Is PROJECTYPE really spelled with only one T?
6)  You should enclose your edits within an edit operation.
PhyllisDavis
Neil,
Thanks for catching my Editor declarations..I fixed that error.  I changed my code to loop through and get the selected feature and update attributes...but the form just closes, it doesn't update the data.  Is this because I don't have it in an edit operation like you said? How do I create and edit operation?
Thanks again for help!
        Dim pMxDocument As IMxDocument
        Dim pMap As IMap
        Dim pEnumLayer As IEnumLayer
        Dim pFeatureSelection As IFeatureSelection
        Dim player As ILayer
        'Get a reference to the editor.
        editor = My.ArcMap.Application.FindExtensionByName("esriEditor.Editor")
        pMxDocument = My.ArcMap.Application.Document
        pMap = pMxDocument.FocusMap
        pEnumLayer = pMap.Layers
        pEnumLayer.Reset()
        player = pEnumLayer.Next
        Do While Not player Is Nothing
            If TypeOf player Is IFeatureLayer Then
                Dim pFLayer As IFeatureLayer
                pFLayer = player
                pFeatureSelection = pFLayer
                If pFeatureSelection.SelectionSet.Count <> 0 Then
                    pFeatureSelection.SelectionSet.Search(Nothing, False, pFCursor)
                    Dim pFeature As IFeature
                    pFeature = pFCursor.NextFeature
                    If Not pFeature Is Nothing Then
                        End If
                        'Get SelectionSet
                        Dim pSelSet As ISelectionSet
                        pSelSet = GetSelection(pFLayer)
                        'Get FeatureCursor from SelectionSet
                        pSelSet.Search(Nothing, True, pFCursor)
                        pFeature.Value(pFeature.Fields.FindField("YEAR")) = txtPrjYear.Text
                        pFeature.Value(pFeature.Fields.FindField("PROJECTYPE")) = txtPrjType.Text
                        pFeature.Value(pFeature.Fields.FindField("LOCATION")) = txtLocation.Text
                        pFeature.Value(pFeature.Fields.FindField("AGENCY")) = txtAgency.Text
                        pFeature.Value(pFeature.Fields.FindField("DESCRIPTION")) = txtDescrip.Text
                        pFeature.Value(pFeature.Fields.FindField("COST")) = txtCost.Text
                        pFeature.Value(pFeature.Fields.FindField("DATEEDITED")) = txtDate.Text
                        pFeature.Value(pFeature.Fields.FindField("USEREDITED")) = txtUser.Text
                    End If
                End If
            End If
        Loop
        'pFeature.
        editor.StopEditing(True)
        'Close form
        Me.Close()
    End Sub
    Public Function GetSelection(ByVal pFeatLyr As IFeatureLayer) As ISelectionSet
        'Gets selection of feature layer and returns selection set
        'Initialize the required variables
        pMxDoc = My.ArcMap.Application.Document
        Dim pFeatSel As IFeatureSelection
        pFeatSel = pFeatLyr
        GetSelection = pFeatSel.SelectionSet
    End Function
End Class
PhyllisDavis
I changed my code some...and all of the errors are out of my program, except I get an error in my immediate window that says:" Am I not referencing the Editor or another toolbar correctly?
            Dim pMap As IMap
            pEnumLayer.Reset()
            'Verify there are layers located in Map
                    Dim pF As IFeature
                    If editor.EditState <> esriEditState.esriStateNotEditing Then
                    End If
                    If pFLayer.SelectionSet.Count <> 0 Then
                        pF.Value(pF.Fields.FindField("YEAR")) = txtPrjYear.Text
                        pF.Value(pF.Fields.FindField("PROJECTYPE")) = txtPrjType.Text
                        pF.Value(pF.Fields.FindField("LOCATION")) = txtLocation.Text
                        pF.Value(pF.Fields.FindField("AGENCY")) = txtAgency.Text
                        pF.Value(pF.Fields.FindField("DESCRIPTION")) = txtDescrip.Text
                        pF.Value(pF.Fields.FindField("COST")) = txtCost.Text
                        pF.Value(pF.Fields.FindField("DATEEDITED")) = txtDate.Text
                        pF.Value(pF.Fields.FindField("USEREDITED")) = txtUser.Text
                    End If
                    pF.Store()
                End If
            Next Count
            'Kill form
            Me.Close()
    End Sub
NeilClemmons
Honored Contributor
What is the exact message?  You should be able to copy/paste from the Visual Studio window.
