Assertion error on ExportToPDF function.
3160
7
12-15-2011 08:25 AM
JasonTaylor
Hi, I'm new to ArcMapping with Python. For my first task I decided to do a batch export of maps. My code is simple but I get an error that has me stumped.
import arcpy, os
inpath="C:\\GIS\\MXD_dir\\"
outpath="C:\\Out_map_dir\\"
dirList = os.listdir(inpath)
arcpy.OverWriteOutput = 1
for item in dirList:
    print inpath + item
    arcpy.mapping.ExportToPDF(inpath + item, outpath + item[:-4] + ".pdf" )
    arcpy.mapping.ExportToJPEG(inpath + item, outpath + item[:-4] +".jpg" )
and here is my error...
  File "C:\GIS\Scripts\pdf_export.py", line 9, in <module>
  File "C:\Program Files\ArcGIS\Desktop10.0\arcpy\arcpy\utils.py", line 179, in fn_
    return fn(*args, **kw)
  File "C:\Program Files\ArcGIS\Desktop10.0\arcpy\arcpy\mapping.py", line 790, in ExportToPDF
    assert isinstance(map_document, MapDocument)
AssertionError
Any help or insight would be appreciated. Thanks!
MikeMacRae
You might be having issue joining your path name to your file name. try something like:
arcpy.mapping.ExportToPDF(inpath + "\\" + item, outpath + "\\" + item[:-4] + ".pdf" )
JasonTaylor
I thought I took care of that in the when I set the path in in the path variable by adding "\\" there. I tried it any way and got the same error. Thanks though.
MikeMacRae
I have a feeling it has something to do with the way your are looping through your mxd's using dirList = os.listdir(inpath).
I have a similar code to flip through a directory of .mxd's and exports to pdf. Try this:
import arcpy, glob, os, sys
inpath = r"C:\GIS\MXD_dir\"
outpath=r"C:\Out_map_dir\"
for filename in glob.glob(os.path.join(inPath, "*.mxd")):
        fullpath = os.path.join(inPath, filename)
        mxd = arcpy.mapping.MapDocument(filename)
        if os.path.isfile(fullpath):
            basename, filename2 = os.path.split(fullpath)
            shortname, extension = os.path.splitext(filename2)
            arcpy.mapping.ExportToPDF(mxd, outpath + "\\" + shortname, "PAGE_LAYOUT")
            del mxd
            del shortname
            del basename
            del filename2
            del extension
del filename
JasonTaylor
Yes, this works great. Thanks for helping me through this.
I need to research more about glob and the os.path functions, because I'm not sure why it won't work. Your definitely right though, there is a difference.
Thanks again for the help!
JeffBarrette
It wasn't working because the first parameter in your original ExportToPDF and ExportToJPG functions were using an MXD path, not an MXD reference.
Jeff
JasonTaylor
Ah, I see. This was the crucial line I was missing
Adding it, my code works great!
import arcpy, os
        mxd = arcpy.mapping.MapDocument(inpath + item)
        arcpy.mapping.ExportToPDF(inpath + item, outpath + item[:-4])
        arcpy.mapping.ExportToJPEG(inpath + item, outpath + item[:-4])
I also removed the the output extensions, not sure if that matters though.
Thanks again!
DianeMcConnaughey
Thank you!  I was missing  mxd = arcpy.mapping.MapDocument(mxdname), and this line before using arcpy.mapping.ExportToPDF
fixed the problem.
