Data Driven Pages: Can Only Show Unique Feature
1209
12-08-2011 04:46 PM
ChristopherStebbins1
I am using a polygon feature class as the map index.  Does anyone know of a way to only show the specific feature in focus, rather than the other adjacent/nearby features in the map index?
I believe I was able to do this in previous versions of ArcGIS.
Chris
JohnSobetzer
Honored Contributor
You might try using a Page Definition query on your layer in its Properties after setting up the DDP.
You can also clip using the Data Frame Properties - Data Frame - Clip Options
RyanCircello
In the setup data driven pages dialogue box, under the extent tab make sure if you are using the best fit option that the margin size is set to zero or use the "center and maintain current scale".
