trouble migrating vba to .net for draw polygon buffers
1898
12-07-2011 04:57 AM
BenAller
I'm new to .net and trying to adapt a version of the vba sample below to work as an add-in tool.
Here's the original: http://resources.esri.com/help/9.3/arcgisdesktop/com/samples/arcmap/83691e5d-1029-463c-b87a-0f40519f...
I think I'm getting stuck on calling the mousedown and active view events.
Any help would be greatly appreciated.
Ben
'Draws 1/4 mile buffer on top most polygon layer.
Option Explicit On
Imports ESRI.ArcGIS.esriSystem
Imports ESRI.ArcGIS.ArcMapUI
Imports ESRI.ArcGIS.Carto
Imports ESRI.ArcGIS.Geometry
Imports ESRI.ArcGIS.Display
Imports ESRI.ArcGIS.Geodatabase
Imports ESRI.ArcGIS.ArcCatalog
Public Class NitrateBufferTool
    Inherits ESRI.ArcGIS.Desktop.AddIns.Tool
    Private WithEvents ActiveViewEvents As Map
    Private m_pMxDoc As IMxDocument
    Private m_pBufferPolygon As IPolygon
    Private m_pLastBufferedExtent As IEnvelope
    Private m_pFillSymbol As ISimpleFillSymbol
    Private m_pOutlineSymbol As ISimpleLineSymbol
    Public Sub New()
    End Sub
    Protected Overrides Sub OnUpdate()
        Enabled = My.ArcMap.Application IsNot Nothing
    End Sub
    Private Sub ActiveViewEvents_AfterItemDraw(ByVal Index As Integer, ByVal display As IDisplay, ByVal phase As ESRI.ArcGIS.esriSystem.esriDrawPhase)
            'Only draw in the geography phase
            If Not phase = ESRI.ArcGIS.esriSystem.esriDrawPhase.esriDPGeography Then Exit Sub
            'Draw the buffered polygon
            If m_pBufferPolygon Is Nothing Then Exit Sub
            With display
                .SetSymbol(m_pFillSymbol)
                .DrawPolygon(m_pBufferPolygon)
            End With
    End Sub
    Private Sub ActiveViewEvents_SelectionChanged()
            Dim pActiveView As IActiveView
            Dim pEnumFeature As IEnumFeature
            Dim pFeature As IFeature
            Dim pPolygon As IPolygon
            Dim pTopoOperator As ITopologicalOperator
            Dim pGeometryBag As IGeometryCollection
            pActiveView = m_pMxDoc.FocusMap
            pGeometryBag = New GeometryBag
            'Flag last buffered region for invalidation
            If Not m_pLastBufferedExtent Is Nothing Then
                pActiveView.PartialRefresh(esriViewDrawPhase.esriViewGeography, Nothing, m_pLastBufferedExtent)
            End If
            If m_pMxDoc.FocusMap.SelectionCount = 0 Then
                'Nothing selected; don't draw anything; bail
                m_pBufferPolygon = Nothing
                Exit Sub
            End If
            'Buffer each selected feature
            pEnumFeature = m_pMxDoc.FocusMap.FeatureSelection
            pEnumFeature.Reset()
            pFeature = pEnumFeature.Next
            Do While Not pFeature Is Nothing
                pTopoOperator = pFeature.Shape
                pPolygon = pTopoOperator.Buffer(1320)
                pGeometryBag.AddGeometry(pPolygon)
                'Get next feature
            Loop
            'Union all the buffers into one polygon
            m_pBufferPolygon = New Polygon
            pTopoOperator = m_pBufferPolygon 'QI
            pTopoOperator.ConstructUnion(pGeometryBag)
            m_pLastBufferedExtent = m_pBufferPolygon.Envelope
            'Flag new buffered region for invalidation
            pActiveView.PartialRefresh(esriViewDrawPhase.esriViewGeography, Nothing, m_pBufferPolygon.Envelope)
            'Zoom to the buffer extent
            Dim pEnvelope As IEnvelope
            pEnvelope = New Envelope
            pEnvelope.PutCoords(m_pBufferPolygon.Envelope.XMin - 1, m_pBufferPolygon.Envelope.YMin - 1, _
                              m_pBufferPolygon.Envelope.XMax + 1, m_pBufferPolygon.Envelope.YMax + 1)
            pEnvelope.Expand(1, 1, True)
            pActiveView.Extent = pEnvelope
            pActiveView.Refresh()
    End Sub
    Private Sub OnMouseDown(ByVal button As Long, ByVal shift As Long, ByVal x As Long, ByVal y As Long)
        MsgBox("mousedown")
        Dim pMxApp As IMxApplication
        Dim pMxDoc As IMxDocument
        Dim pMap As IMap
        Dim pRubberEnv As IRubberBand
        Dim MxStatusBar As IStatusBar
        Dim pProgAnim As IAnimationProgressor
        pRubberEnv = New RubberEnvelope
        pMxApp = My.ArcMap.Application
        pMxDoc = pMxApp.Document
        pMap = pMxDoc.FocusMap
        pActiveView = pMap
        pProgAnim = MxStatusBar.ProgressAnimation
        pEnvelope = pMxDoc.CurrentLocation.Envelope
        pEnvelope.Expand(pMxDoc.SearchTolerance, pMxDoc.SearchTolerance, False)
        'Refresh the old selection to erase it
        pActiveView.PartialRefresh(esriViewDrawPhase.esriViewGeoSelection, Nothing, Nothing)
        If shift = 1 Then
            pMxApp.SelectionEnvironment.CombinationMethod = ESRI.ArcGIS.Carto.esriSelectionResultEnum.esriSelectionResultXOR
        Else
            pMxApp.SelectionEnvironment.CombinationMethod = ESRI.ArcGIS.Carto.esriSelectionResultEnum.esriSelectionResultNew
        End If
        'Play the progress animation
        pProgAnim.Show()
        pProgAnim.Play()
        MxStatusBar.PlayProgressAnimation(True)
        'Perform the selection using a point created on mouse down
        pMap.SelectByShape(pEnvelope, pMxApp.SelectionEnvironment, True)
        'Refresh again to draw the new selection
    End Sub
    Protected Overrides Sub OnActivate()
        MsgBox("OnActivate")
        Dim pMap As IMap
        Dim pFeatureLayer As IFeatureLayer
        Dim pGC As IGraphicsContainer
        Dim pViewManager As IViewManager
        Dim pRgbColor As IRgbColor
        m_pMxDoc = My.ArcMap.Document
        pMap = m_pMxDoc.FocusMap
        pActiveView = m_pMxDoc.ActiveView
        MxStatusBar = My.ArcMap.Application.StatusBar
        pGC = pMap
        pGC.DeleteAllElements()
        pViewManager = m_pMxDoc.FocusMap
        pViewManager.VerboseEvents = True
        ActiveViewEvents = m_pMxDoc.FocusMap
        'Play some progress animation
        pProgAnim.Show()
        pProgAnim.Play()
        'Create the fill symbol
        m_pFillSymbol = New SimpleFillSymbol
        m_pOutlineSymbol = m_pFillSymbol.Outline
        m_pFillSymbol.Style = ESRI.ArcGIS.Display.esriSimpleFillStyle.esriSFSHollow
        'Create the outline symbol
        m_pOutlineSymbol.Style = ESRI.ArcGIS.Display.esriSimpleLineStyle.esriSLSSolid
        m_pOutlineSymbol.Width = 4
        pRgbColor = New RgbColor
        pRgbColor.Red = 197
        pRgbColor.Green = 0
        pRgbColor.Blue = 255
        m_pOutlineSymbol.Color = pRgbColor
        m_pFillSymbol.Outline = m_pOutlineSymbol
        MsgBox("finished OnActivate")
    End Sub
End Class
BenAller
I revisited this and got it working as an add-in.  The "Add Event Wiring for All IActiveViewEvents Snippet" was helpful.
Code:
    'Declare Event Handlers
    Private m_ActiveViewEventsAfterItemDraw As ESRI.ArcGIS.Carto.IActiveViewEvents_AfterItemDrawEventHandler
    Private m_ActiveViewEventsSelectionChanged As ESRI.ArcGIS.Carto.IActiveViewEvents_SelectionChangedEventHandler
    End Sub
    'Set up the event handlers for the IActiveViewEvents
    Private Sub SetupActiveViewEvents(ByVal map As ESRI.ArcGIS.Carto.IMap)
        If map Is Nothing Then
            Return
        End If
        Dim activeViewEvents As ESRI.ArcGIS.Carto.IActiveViewEvents_Event = TryCast(map, ESRI.ArcGIS.Carto.IActiveViewEvents_Event)
        'Create an instance of the delegate, add it to AfterItemDraw event
        m_ActiveViewEventsAfterItemDraw = New ESRI.ArcGIS.Carto.IActiveViewEvents_AfterItemDrawEventHandler(AddressOf OnActiveViewEventsAfterItemDraw)
        AddHandler activeViewEvents.AfterItemDraw, m_ActiveViewEventsAfterItemDraw
        'Create an instance of the delegate, add it to SelectionChanged event
        m_ActiveViewEventsSelectionChanged = New ESRI.ArcGIS.Carto.IActiveViewEvents_SelectionChangedEventHandler(AddressOf OnActiveViewEventsSelectionChanged)
        AddHandler activeViewEvents.SelectionChanged, m_ActiveViewEventsSelectionChanged
    End Sub
        MyBase.OnActivate()
        Dim pMap As IMap
        Dim m_pMxDoc As IMxDocument
        Dim ActiveViewEvents As ISelectionEvents
        pGC = pMap
        pMap = Nothing
        pGC = Nothing
        pRgbColor.Red = 197
        pRgbColor.Green = 0
    End Sub
    Protected Overrides Sub OnMouseDown(ByVal arg As ESRI.ArcGIS.Desktop.AddIns.Tool.MouseEventArgs)
        MyBase.OnMouseDown(arg)
        Dim pMap As IMap
        pActiveView = pMap
        'Fire off the event listener
        SetupActiveViewEvents(pMap)
        If arg.ModifierKeys = (System.Windows.Forms.Keys.Shift) Then
        Else
        End If
    End Sub
    'AfterItemDraw Event handler
    Private Sub OnActiveViewEventsAfterItemDraw(ByVal Index As Integer, ByVal display As ESRI.ArcGIS.Display.IDisplay, ByVal phase As ESRI.ArcGIS.Carto.esriViewDrawPhase)
        'Only draw in the view geography phase
        If Not phase = esriViewDrawPhase.esriViewGeography Then Exit Sub
        With display
        End With
    End Sub
    'SelectionChanged Event handler
    Private Sub OnActiveViewEventsSelectionChanged()
        Dim pmap As IMap
        m_pMxDoc = pMxApp.Document
        pmap = m_pMxDoc.FocusMap
        End If
            Exit Sub
        End If
            'Get next feature
        Loop
    End Sub
End Class
