Web Editing using Versioning
1136
12-01-2011 09:48 PM
KubilayKüpeli
Is there a way to do editing with versions through the Rest API like it is in the Web ADF?
BR
TonyContreras
"Versioned and unversioned data is supported; however, versioning is required if you plan on editing nonsimple types (for example, network edges) with the service."
Authoring feature services
KubilayKüpeli
Thanks for your answer. What if i want to let a user to edit her own version through the web interface using credentials.
To be more precise, like in the desktop, when i connect to the sde using my credentials, i access to the versions i can view or edit. In our project, we want to make something like this. The user enters credentials, the system automatically selects users version from database, and the user works on this version in that session.
BR.
RaviNarayanan
BR,
The upcoming release (10.1) will support editing features in a named version.  In 10.0, you can only edit the version of data that is published in the service.
