Paged Export
2222
11-23-2011 09:27 AM
Jackde_Valpine
I am trying to get the paged_export.py script working, written by Ben Sunshine-Hill and referenced in the following archived thread:
http://www.procedural.com/support/forum.html?tx_mmforum_pi1%5Baction%5D=list_post&tx_mmforum_pi1%5Bt...
One minor change is required in def make_export_settings():
#    EXPORT_SETTINGS = FBX20112ExportModelSettings()
    EXPORT_SETTINGS = FBXExportModelSettings()
However, when I try to run the script (F9) with geometry selected I get an error indicating:
Python script does not exist: map_exporter.py (PyException)
Does anyone know anything about this?
-Jack de Valpine
NathanJosway
Hi Jack,
I had the same issue and the solution was to create a new python file in the current project script folder called map_exporter.py and I used the Module: Main template.  Once you have this file everything should run properly.
Nate
Jackde_Valpine
Hi Nate,
Many thanks, that did the trick!
Best,
-Jack
