Sum rows of a field
1262
11-23-2011 07:51 AM
RichardThurau
I'm trying to create a single scalar value as the sum of a row, then use the scalar in a field calculation:
I want the sum of "UTC10_FT" call it tot_utc_ft, then use that value in a calculate field:
to find the sum value:
list2 = []
rows = arcpy.SearchCursor(fc)
for row in rows:
    utc_ft = row.getValue("UTC10_Ft")
    list2.append(utc_ft)
    tot_utc_ft = sum(list2)
arcpy.CalculateField_management(parcels, "Tot_UTC_Pct", """!UTC10_Ft! / tot_utc_ft""", "PYTHON")
Currently getting this error:
    tot_utc_ft = sum(list)
TypeError: unsupported operand type(s) for +: 'float' and 'NoneType'
I'm sure this is something simple, but admittedly, not a great python programmer.
The next question will be whether python will use my tot_utc_ft variable within field calculator? Or, do I need to perform this operation within an expression?
Thanks for your help.
rich
JakeSkinner
Esri Esteemed Contributor
Hi Rich,
I believe you are receiving that error because you have a NULL, or empty, value for one of the rows.  Perform a search by attribute and then convert all NULL values to 0 and try your script again.  Also, you will be able to use the variable in the field calculator.
HemingZhu
list2 = []
for row in rows:
rich
Looks like some of your row.UTC10_Ft has null value in it. -never mind. Jake says it
RichardThurau
Many Thanks!! Pesky nulls.
