The iOS API 2.1 says:
"The envelope property on AGSMapView has been deprecated and replaced by visibleArea to take into account map rotation."
When I change to :
AGSEnvelope *env = self.mapView.visibleArea;
I get this error:
Incompatible pointer types initializing 'AGSEnvelope *' with an expression of type 'AGSPolygon *'
Nimesh : Your answer was
The visibleArea returns AGSPolygon and you are trying to save it as AGSEnvelope. Hence the error. If you want envelope then change code line as following,
AGSEnvelope *env = self.mapView.visibleArea.envelope;
I tried this, and now I get an EXC Bad Access error on the zoom to envelope call.
I do this:
then this:
// remove all layers from the mapView
[self.mapView reset];
// add the layers back in with the correct order
if (_currentTMS.loaded == YES){
[self.mapView addMapLayer:_currentTMS withName:@"tiledLayer"];
[self.mapView addMapLayer:baseLayer withName:@"baseLayer"];
[self.mapView addMapLayer:_currentFMS withName:@"featureLayer"];
[self.mapView addMapLayer:_currentGL withName:@"Parcel Outline Graphics Layer"];
[self.mapView zoomToEnvelope:env animated:NO];
the error is onthe zoomToEnvelope.
This all worked fine when it was just AGSEnvelope *env = self.mapView.envelope;
Any suggestions?
