'module' object has no attribute 'getParameterAsText'
4110
11-22-2011 03:25 AM
DaveJordan1
I have just begun wrinting a script and am hitting a wall...  I get the following message:
Running script ParcelBuffer...
<type 'exceptions.AttributeError'>: 'module' object has no attribute 'getParameterAsText'
Failed to execute (ParcelBuffer).
Here is all that is in the script:
# Import arcpy module
import arcpy
from arcpy import env
import os
# Local variables:
mxd = arcpy.mapping.MapDocument("Current")
# Set variables from user input
RequestID = arcpy.getParameterAsText(1)
Dist = arcpy.getParameterAsText(2)
What is wrong with this?
GeorgeNewbury
Try a capital G.
arcpy.GetParameterAsText(0)
GeorgeNewbury
Try a capital G.
DaveJordan1
That did the trick.  Also, I was using 1 instead of 0 for the first parameter...
Thank you!
