Cluster analysis using spatial and temporal data
2838
11-06-2011 07:52 PM
GregHacker
Hi all,
I am hoping to conduct a cluster analysis and my data contains:
10 sites (isolated offshore rocks).
Three summers' worth of "counts" at each site (these are dates, varying numbers of surveys per month, usually from about May to September).
and 5 "groups" which are loosely defined age classes of sea lions.
I would like to go further than what a normal hierarchical cluster analysis would do by adding a temporal variable, as well as the age class variable.  I have seen other sea lion studies specifically use the HCA with just abundance data (monthly), and several sites, but I understand that my data is a bit more complicated.  The results I am looking for, are groupings of sites by age class - ie: a certain age class is more likely to use certain sites over others, and whether that changes over time.
Any help would be GREATLY appreciated!  Thank you!
Allison F.
JeffreyEvans
Allison,
Unfortunately, you are fairly limited in your options here. The only, somewhat accessible, space/time clustering approach that I am aware of is SatScan (http://www.satscan.org/).
