Batch export mxd, python mapping module
2366
10-21-2011 10:11 AM
RichardThurau
Hi esri community,
I'm trying to use a fairly simple script to export a list of map layouts (mxds) in a folder to pngs. should be easy but...
import arcpy
ws = arcpy.env.workspace = "X:\\Draft3Maps"
outDir = "X:\\Draft3_Map_graphics"
mapList = arcpy.ListFiles("*.mxd")
arcpy.mapping.MapDocument(mapList)
for mxd in mapList:
    #arcpy.mapping.MapDocument(mxd)
    print mxd
    arcpy.mapping.ExportToPNG(mxd, outDir + '\\' + str(mxd))
    del mxd
Error message:
  File "X:\export_mxd_to_PNG.py", line 8, in <module>
  File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\arcobjects\mixins.py", line 443, in __init__
    assert (os.path.isfile(mxd) or (mxd.lower() == "current")), gp.getIDMessage(89004, "Invalid MXD filename")
  File "C:\Apps\Python26\ArcGIS10.0\lib\genericpath.py", line 29, in isfile
    st = os.stat(path)
TypeError: coercing to Unicode: need string or buffer, list found
I know I'm probably close but probably missing something key. Any help is greatly appreciated.
Rich
RichardThurau
Seems I've been a little quick on the forums gun:
import arcpy
for m in mapList:
    print m
    mxd = arcpy.mapping.MapDocument("X:\\Draft3Maps\\" + m)
    arcpy.mapping.ExportToPNG(mxd, outDir + '\\' + str(m))
    del mxd
Works in case anyone is interested.
Rich
