Invalid SQL Statement SelectLayerByLocation
1204
10-20-2011 11:32 AM
LornaMurison
Hey everyone,
The following is the first thing that my script does after setting up variables etc...
# Create Fishnet
desc = gp.describe (streams)
xmin = desc.extent.xmin
ymin = desc.extent.ymin
xmax = desc.extent.xmax
ymax = desc.extent.ymax
origin_coord = str (xmin) + " " + str(ymin)
y_axis_coord = str (xmin) + " " + str(ymin + 10)
corner_coord = str (xmax) + " " + str(ymax)
gp.CreateFishnet_management ("Fishnet.shp", origin_coord, y_axis_coord, 0, 0, 2, 2, corner_coord, "NO_LABELS", "")
# Convert the Fishnet to Polygon
gp.FeatureToPolygon_management("Fishnet.shp", "FishnetPoly.shp", "#", "NO_ATTRIBUTES", "")
# Calculate ID Field with Incremental number
gp.CalculateField_management("FishnetPoly.shp", "id", "autoIncrement()", "PYTHON_9.3", "rec=0\\ndef autoIncrement():\\n global rec\\n pStart = 1 #adjust start value, if req'd \\n pInterval = 1 #adjust interval value, if req'd\\n if (rec == 0): \\n  rec = pStart \\n else: \\n  rec = rec + pInterval \\n return rec")
# Add and Calculate Text Field (SplitField) With That Same Number
gp.AddField_management("FishnetPoly.shp", "SplitField", "TEXT", "#", "#", 1, "", "NULLABLE", "NON_REQUIRED", "")
gp.CalculateField_management("FishnetPoly.shp", "SplitField", '"id"', "VB", "")
# Loop Through Each FishnetPoly Cell and Select Those Catchments That Have Their Center In The Given Cell
for i in range (1,5,1):
    ### Make Feature Layer From First Fishnet Cell
    gp.MakeFeatureLayer_management ("FishnetPoly.shp", "FishnetCell", '"SplitField" = ' + str(i), gp.Workspace, "")
    ### Make Feature Layer From Catchments
    gp.MakeFeatureLayer_management (catchments, "CatchmentsLayer", "", gp.Workspace, "")
    ### Select Catchments Which Have Their Center in the Feature Layer Cell
    gp.SelectLayerByLocation_management ("CatchmentsLayer", "HAVE_THEIR_CENTER_IN", "FishnetCell")
It returns the following error at gp.SelectLayerByLocation_management...
ExecuteError: ERROR 999999: Error executing function.
An invalid SQL statement was used.
A locator with this name does not exist.
Failed to execute (SelectLayerByLocation).
I have no idea why.  I don't know what SQL statement it could be referring to.
Any ideas?
LornaMurison
Turns out that the first make feature layer method was using an SQL statement that was resulting in an empty layer.
I changed:
to:
gp.MakeFeatureLayer_management ("FishnetPoly.shp", "FishnetCell", '"SplitField" = ' + "'" + str(i) + "'", gp.Workspace, "")
because the field I was selecting is a text field, even though it contains a number, str(i) needed single quotes.
That solved the problem.
DaveJohnson
Thanks...struggled with this one for a while before I found your post.  Pulling a number from a text column required extra single quote around the number.
