Using a nested loop
818
10-17-2011 10:45 PM
DemetrisDemetriou
I use the following nested loops to read the first point feature of a dataset and the rest points in that dataset. Then read the second point feature of a dataset and the rest points in that dataset and so on. The problem with these nested loops is that it reads the first point and the rest points only once. Why this happens?
    Dim pFCursor As IFeatureCursor
    Set pFCursor = pFeatureClass.Search(Nothing, True)
    Dim pFCursor2 As IFeatureCursor
    Set pFCursor2 = pFeatureClass.Search(Nothing, True)
    Dim pFeature As IFeature
    Dim pFeature2 As IFeature
    Dim pPointA As IPoint
    Dim pPointB As IPoint
    Set pFeature = pFCursor.NextFeature
    Do Until pFeature Is Nothing
    Set pPointA = pFeature.Shape
    MsgBox pFeature.Value(intPosFID) & "F1"
       Set pFeature2 = pFCursor2.NextFeature
       Do Until pFeature2 Is Nothing
             Set pPointB = pFeature2.Shape
             MsgBox pFeature2.Value(intPosFID) & "F2"
       Loop
       Loop
DuncanHornby
MVP Notable Contributor
I think you need to reset the second feature cursor with each loop of your first feature cursor.  You code should look like:
    Loop
Loop
Duncan
p.s. Please place your code samples inside the code tags (the # symbol on the toolbar)
DemetrisDemetriou
Yes, Duncan. You are right! That was the mistake. Thank you very much.
Demetris
