Bug in ArcGIS app in iOS 5
825
10-17-2011 10:34 AM
PaulFrey
Using the iPad ArcGIS app, updated to iOS 5 a new problem has come up. I have a map comprised off only my map services, in which i have a group of layers called "Environmental". The group is turned on but none of the layers inside of it are turned on. When the map first loads, every layer in that group turns on, causing problems obviously. They go away when I turn the group off however (even though individually they all say they are off). Anyone know whats causing this? This didn't happen with iOS 4, and isn't a problem on the arcgis.com viewer
-Paul
PaulLohr
Usually right after a new release becomes available, responses from ESRI are a little on the thin side. I suspect they are working diligently to resolve a few issues. If you can wait a bit, the resolution will probably come shortly.
Sorry I could not be of more help.
Paul Lohr
Paul Lohr
Lohr Geospatial Services, Inc.
