Get Count While Applying a filter
1632
10-14-2011 06:36 AM
ChristinaGnadinger
I hope this is something easy to do, although I can't find the right formula to make this work.
I am trying to run a filter on a table to find features who have a specific field blank. I ultimately want to output that count of features out to a text file. The trouble I am having is that GetCount_management does not work correctly when I try and apply a filter to it.
Right now I have ..
filter = "\"FACILITY_I\" = ' '"
lyr = "C:\\Users\\gisadmin\\Desktop\\TEST\\FH_Test.shp"
result = int(arcpy.GetCount_management(lyr).getOutput(0))
print result
and that works .. but it's (obviously) giving me the total since the filter is not referenced in at all. When I try and build a filter in I start getting errors, typically Runtime errors in executing tool.
Does someone know how to run this function while applying a filter, or another way to accomplish the same goal?
Also, as opposed to printing the results to a screen I'd like to write them to a table, however I'm moving from vB into Python so I'm still learning the language.
Any advice or help would be greatly appreciated. Thank you!
MarcNakleh
Hello Christina,
What you need is the Make Feature Layer method. It works almost identically to Select By Attribute in ArcMap or ArcCatalog: it will use the filter and generate a layer of features that satisfied the filter condition.
shp = r"C:\Users\gisadmin\Desktop\TEST\FH_Test.shp"
lyr = arcpy.MakeFeatureLayer(shp, filter)
print result
And your output can go wherever you want, depending on what format you're looking at. To write it to a table, you could use a Cursor object. If you're writing it to a table in a textfile or CSV, you could write it using Python's builtin open function. With a little more information, this shouldn't be hard to do.
I hope this helps!
ChristinaGnadinger
Thank you for your help so far! Luckily it's not erroring out on the filter, however it's not acknowledging it either. On this test set I still get 89 no matter what. I've even tried altering the filter to make sure it wasn't incorrectly typed but that is not helping.
Anyway I have it not erroring and now printing to the test file, so if I can figure out how to get the filter to work then I'll be set!
Thank you!
ChristinaGnadinger
I found the tweak I needed. Thank you for your help!!
lyr = arcpy.MakeFeatureLayer_management(shp, "FH_Test_lyr", filter)
outtable.write(str(result))
print result
