Map data not yet available
4063
10-11-2011 03:15 AM
FrankSmith
Is there any way to prevent the "Map data not yet available" message from appearing when zooming in past the layer with the highest available resolution, and instead have the highest resolution imagery enlarged appropriately?
Basically, I'd like to be able to view certain geographic features (from e.g. http://services.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer) on my screen (e.g. a cove or a lake) so that they take up a large amount of screen space. It doesn't matter so much if the image is a little fuzzy from enlargement.
-Frank.
MichaelBranscomb
Esri Frequent Contributor
The "Map data not yet available" message comes from the tiled map service itself, which means there is not anything directly you can do to control this (other than use your own local tiled package based on your own data). However, we are considering providing an option to override this which would mean for example, dropping back to the previous available level of cache and accepting some blurriness.
Thanks for your feedback.
Cheers
Mike
FrankSmith
Thanks, Mike.  The option you described sounds perfect!
-Frank
