Select case syntax and use of wildcards
916
10-07-2011 06:35 AM
EdRollason
I have a string variable (AssetID_Val) which is assigned from a previous element of code.  I want to compare the variable against some set values and assign another variable according to the value of AssetID_Val.
I assume that a select case is the best way of doing this but am not sure of the correct syntax.  I also want to introduce a wildcard character into the select case as AssetID_Val will have a variable number.
This is what I've come up with so far but it isn't working:
Select Case AssetID_Val
    Case Is = "ND_*"
    Set pStdAloneTbl = pMap2.StandaloneTable(0)
    Case Is = "LK_*"
    Set pStdAloneTbl = pMap2.StandaloneTable(1)
    Case Is = "PG_*"
    Set pStdAloneTbl = pMap2.StandaloneTable(2)
    Case Else
    MsgBox "Error"
    pEditor.AbortOperation
    Exit Sub
End Select
The * indicates a 3 digit number which will change each time.  I can't work out whether the error is with my Case syntax or with the introduction of the wildcard.  Help on both would be appreciated.
Cheers
Ed
JamesCrandall
Ed
Ed,
If the first 3 characters are what you are interested in searching, meaning that anything before the _underscore is what you want to match, then you could just set a new string variable to the first 3 characters and run your Select Case on that.  This would mean that you are only looking to Select the first 3 chars (rather than attempting the wildcard, which I don't think will work).
Something like this:
            Dim AssetID_Val As String = "PG_123" 'this is manually set to test it out
            Dim srchString As String = Mid(AssetID_Val, 1, 3)
            Select Case srchString
                Case "ND_"
                    MsgBox(AssetID_Val & " Found!")
                Case "LK_"
                Case "PG_"
                Case Else
                    MsgBox("nothing found!")
            End Select
So, in the above example, the MsgBox would popup "PG_123 Found!" because the Select located that the first 3 characters in the AssetID_Val variable are "PG_".  If the AssetID_Val was = "LK_888888", then the msgBox would popul with "LK_888888 Found".
Hope this makes sense!
Here's how your full implementation might look:
    Case "ND_"
    Case "LK_"
    Case "PG_"
    Case Else
    MsgBox "Error"
    Exit Sub
End Select
EdRollason
Hi James,
That seems to work fine, thanks!
Cheers
Ed
JamesCrandall
Hi James,
Cheers
Ed
Excellent!
Take Care,
james
