Using Python - Not a default install
710
10-03-2011 07:06 AM
KentRothrock
Hello there.  I've got a situation where ArcGIS 10 was installed on a G: drive (instead of on the "C:" drive); the default location is: "G:\Software_Install\Desktop10.0".  Meanwhile, Python 2.6 has been installed at "C:\Python26".
As you might imagine, I'm unable to use any geoprocessing scripts with this current configuration.  All I get is:  "Import Error: No module named ArcPY".
The "Desktop10.pth" correctly points the locations of the 'ArcPy' and 'Bin' directories (both on the G: drive with the ArcGIS Desktop install).
What is the easiest way for me to use Python geoprocessing scripts in this configuration?
Any help is appreciated.
Thanks.
JasonScheirer
Esri Alum
Yeah, if C:\Python26\Lib\site-packages\Desktop10.pth exists and is correct, it should jsut work.
Make sure when you import that you use all lower case (import arcpy)
