How to Select the Feature that lies under the mouse click in ArcMap through Vb.Net?
1958
09-20-2011 01:24 AM
dgesridgesri
Greetings,
I simply want to select the feature of the top most layer which is clicked on by the mouse cursor in the map. SO I clicked on the map and I select the feature (of the top most layer) that is located there under the mouse click programmatically and without using or calling the "SelectFeaturesTool" of ArcMap. Is there a vb.net code to do that...
Please it is very critical and hurry!!!
Ariharan
Use the IIdentifyDialog to select single feature from the layer. The following link may usefull for you to use IIdentifyDialog object.
http://forums.arcgis.com/threads/306...d=1#post102767
dgesridgesri
Thank you ariharan3,
I just want to inform you that the link you provided is for a thread that I own,...
again thank you for your interest in this issue...
